Old 08-14-2005, 03:14 PM   #1
Jrok25supra
Jrok25supra is on a distinguished road
I've been looking around for clutch and flywheel prices and alot of the sites ask for n/a or turbo. Are flywheel and clutches for n/a and turbo the same b/c i have a 86.5 n/a car but plan on putting a turbo engine in it. I think they're the same since n/a and turbo transmissions are direct bolt on for both motors.
Jrok25supra is offline   Reply With Quote
Old 08-26-2005, 02:19 PM   #2
Jrok25supra
Well i guess since no one is answering the question then I must have answered my own question.
Old 08-26-2005, 03:47 PM   #3
monkihead
monkihead's Avatar
i didnt know you asked.
the turbo clutch disk is a little larger than a non turbo but have the same splines.
the pressure plate is a pull type for the turbo, a push for the non turbo.
slave cylinders are different as well.
so, to make it simple, if you have an n/a tranny and hardware use n/a listings. BEWARE! you need to have an upgraded clutch to hold the excess torque and hp you will be pushing to it.
monique- better off dead
Old 08-30-2005, 08:53 AM   #4
Jrok25supra
Ok, thanks monkihead, but what about the slave cylinder. Does that have to be changed out since they are different
Old 08-30-2005, 04:35 PM   #5
monkihead
monkihead's Avatar
it will only be different if you use the turbo pressure plate.
the key here is, u can use the turbo clutch disc, even in upgraded form. just not the pressure plate.
7mge-t + 7mgte clutch disc + 7mge pressure plate, 7mge throwout bearing, 7mge slave cylinder = will work.
centerforce makes a really good clutch, plus ive had mine for about 3 months. im pushing high 200s low 300 hp.
p/n df522018
summit racing will probably the cheapest next to ebay.
Old 09-04-2005, 05:35 AM   #6
Jrok25supra
Thanks. I also wanted to know is the NA trans longer than the turbo trans b/c i think i read something about it here. I'm i going to need a drive shaft or can i use the one NA drive shaft.
Old 09-04-2005, 06:12 AM   #7
Poodles
I think they're the same length, but I could be wrong...
Old 09-04-2005, 06:08 PM   #8
monkihead
monkihead's Avatar
crap. i honestly dont know. i've got a spare non turbo tranny here and turbo tranny is on the car. i took the drive shafts since i know the autos are a longer tranny. i had an auto supra at one time.
Old 09-05-2005, 07:29 AM   #9
Jrok25supra
Ok, I'll try to search it since I'm going to be doing a turbo swap into my N/A. I know i'm going to need it b'c i plan on going over 350-400hp and the R154 is better anyway. Thank guys
clutch and flywheel Greg mk3 MKIII Supra 1 08-28-2008 04:22 AM
what clutch and flywheel setup?? boner1115 MKIII Supra 2 06-12-2007 04:53 AM
