Old 10-29-2009, 01:38 AM   #1
dannydavi
dannydavi's Avatar
Default Bolt/ Nut specs???
hey umm i need some info for some lost bolts/ nuts :s unfortunately didnt keep good track of everything when taking my engine out ok the things i need most is the specs on the bolt that hold the starter to the block/transmission area? the ones that go through the bellhousing, i mis placed mine and dont know what to look for when buying at this point and the TSRM doesnt help me in this department, also the nut on the starter that you fasten the hot lead with i have lost, these things would be easy to find out if the starter was easy to get to, and I'd rather not buy and try a bunch of bolts, thanks in advance for any info/charts/etc.. or link to spot in TSRM where it might tell me this info
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-29-2009, 08:14 PM   #2
http://www.tampabaysupras.com/files/...eFasteners.pdf
Old 10-29-2009, 11:47 PM   #3
dannydavi
dannydavi's Avatar
wow priceless chart CRE, thanks for your response and your information, it is greatly appreciated, I actually called the toyota dealer earlier today and found out the 10mm x 1.25 measurements but they did not have the length.. but i will save this link for future use for sure, thanks again.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-31-2009, 01:58 AM   #4
ddmcse
ddmcse's Avatar
Cool
i have a bag of bolts from my conversion . i'll look in tomorrow
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 11-02-2009, 05:54 AM   #5
dannydavi
dannydavi's Avatar
ok so nut that holds wire onto starter is a 8mm x 1.25 pitch and bolt that holds starter onto bellhousing is 10mm x 1.25 pitch and the length was about 2 inches.
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
A Little Story about a crank bolt abhattan MKIII Supra 17 03-28-2013 01:06 AM
Help on head bolt torque specs omar MKIII Supra 3 07-29-2009 11:35 AM
stripped rear end bolt 87 Supra MKIII Supra 5 10-16-2007 02:40 PM
Broken Bolt scruffboy Non-Generation Specific Questions 6 10-31-2006 01:33 PM
head bolt specs skunk MKIII Supra 3 07-13-2005 07:29 PM
