Old 10-23-2009, 04:15 AM   #1
ricerbaby
ricerbaby is on a distinguished road
Default starting issue 88 supra automatic w/turbo help!
i have an 1988 supra and it has had problems in the past. we put a jdm in it a few years ago and we had to replace the headgasket and other things. it will not start about 10% of the time. i will try to start it and it will turn over and over but will not start. i will turn it off and start it again and again, but it wont work. it will then start maybe a day later or a few hours, but it is always random. it was in the shop for two weeks and they could not find the problem. they checked all of the fuel lines and pumps, but as soon as they started to get close to the problem it would start up again and the problem wouldnt happen again for maybe a coupple of weeks. it is not the cam wires they were just replaced, and i dont know the problem please help! it is not over heating and not leaking except maybe a few unimporntant vacuum leaks. any ideas???
ricerbaby is offline   Reply With Quote
Old 02-24-2011, 12:02 AM   #2
mpleinwa
mpleinwa is on a distinguished road
Default Similar problem
I have an 1988 Turbo Supra that is having a starting problem also. It will turn over but not start intermittently. Doesn't seem to be related to having a cold or hot engine. I found that if I hold down the pedal to the floor, it will start but it takes 5-10 seconds.
Did you ever find out what was causing your problem?
Thanks/Mark
mpleinwa is offline   Reply With Quote
Old 04-15-2011, 06:25 PM   #3
interested!
Hi!
Had exacly the same problem after MY cylinder head overhaul --engine cranks but will not fire up at-all . my solution : I found a whole bunch of wires UNDER the inlet manifold that should be connected to earth -mine wern't ( forgot they were there! ) -so I did -and then my car started, are yours intermittently connected? ( dry joint/loose bolt/broken wire connector ?) you will need a good mirror and torch -they are to the rear of the manifold under the throttle cable side.
89 Supra Starter Issue, anyone with pictures? destro MKIII Supra 7 05-09-2010 09:13 AM
1989 Toyota Supra Clutch issue bayareasupraboy MKIII Supra 7 10-01-2009 10:48 PM
my 1987 n/a supra automatic tone loc Show n Tell 5 08-03-2006 05:28 AM
