Old 10-15-2009, 03:09 PM   #1
AAPSuprabuilder
AAPSuprabuilder is on a distinguished road
Default coolant level sensor problem
i have a 87 7mge automatic. Every time i make a left turn fairly tight, my low coolant light comes on. where is the sensor located. or might there be something else wrong with it, I just replaced the radiator about a week ago... help...
AAPSuprabuilder is offline   Reply With Quote
Old 10-15-2009, 04:50 PM   #2
2jzmaestro
2jzmaestro is on a distinguished road
I dont know exactly i have an idea, about the issue. Is there enough coolant in the radiator??
if anything use this website so you can locate the part you need. They have diagrams and stuff
http://toyotapartszone.com
hope this helps
2jzmaestro is offline   Reply With Quote
Old 10-16-2009, 02:40 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
The sensor is in the reservoir/overflow bottle. Did you check the fluid level there?
Old 10-25-2009, 02:39 AM   #4
AAPSuprabuilder
THanks that was it. The resevoir was very low
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
coolant on top of piston sevenmgte MKIII Supra 8 05-02-2008 02:34 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
