Old 09-17-2009, 10:39 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Default stripped out exhaust manifold stud
OK so I stripped out the head where one of my exhaust studs bolts in. I just wanted to get some ideas on ways to fix it. I know the proper way to do it I suppose but I am lacking tapping tools, inserts, etc. Anyone got a cheap fix.
It's the centermost stud. dead center.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 09-17-2009, 11:40 PM   #2
mirage83
Don't do a cheap fix. One of the performance Supra aftermarket suppliers has a good quality kit to replace these bolts as the OEM bolts strip far too easily and far too often. I'll look around and see which place it was which carries them.
Old 09-18-2009, 12:36 AM   #3
robertsws
robertsws's Avatar
Thanks, I found the kit at driftmotion for $70 + $15 for standard UPS shipping.
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
Old 07-31-2011, 04:38 PM   #4
my89Supra
my89Supra is on a distinguished road
Default Curious about results
I have the same issue - how did the kit from DriftMotion work out for you ? Thanks.
my89Supra is offline   Reply With Quote
White smoke from exhaust manifold Rommy MKIII Supra 15 07-26-2009 06:32 PM
Non Turbo JZA80 Exhaust Manifold SupraJAZ MKIV Supra 3 04-19-2007 12:19 PM
