Old 11-29-2008, 08:27 PM   #1
SilenceboneSupra
SilenceboneSupra is on a distinguished road
Default Water temperature sensor question!
Hi
Idk if this is the good place to ask but here it goes anyways.
I wanted to replace the water temperature sensor and when unscrewed the old one i noticed that it was longer and thinner then the new one....
Here are some random pictures of some sensors!!
now would the thickness or length make any difference?
the new sensor is for the supra. now i did not change it yet. i dnt know why the new one is shorter nd thicker.. but just want to know before i change it.....
SilenceboneSupra is offline   Reply With Quote
Old 11-30-2008, 07:23 PM   #2
Chambers
Chambers's Avatar
It may be from a diffrent wiring harness, pre 89 or 89+. Check the plug to make sure its the same, other than that it may just be a new design on a old plug.
Good luck.
"Stuck in the 80's"
Old 11-30-2008, 10:49 PM   #3
SilenceboneSupra
Good luck.
its the same plug. just sensors different. but its for the n/a supra.
i asked this on another forums and they been talking about the thinner might get a better reading. but il just go with it and see what happens..
Old 09-08-2009, 05:04 PM   #4
76RA297MGE
76RA297MGE's Avatar
76RA297MGE is on a distinguished road
Default Question about Electric fan and water temp
I would like to adjust the temp setting on my factory electric fan so it will come on at a lower temp. How do I do this? I would like for it to come on around 170 degrees. Is there a way to adjust this setting in the ECU? Please contact me at brian_lindsey1997@yahoo.com
76RA297MGE is offline   Reply With Quote
Won't suck the water from overflow illusive38 MKIII Supra 7 05-24-2012 09:19 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 1 05-27-2008 03:23 AM
Where the h--- is the water going??? illusive38 Non-Generation Specific Questions 0 05-26-2008 09:27 AM
Bad Water Pump? scruffboy Non-Generation Specific Questions 10 11-26-2006 04:37 PM
WAter not going back to raditor from recovery tank Help Jeff_5_7 MKIII Supra 12 09-15-2006 03:49 AM
