Old 08-19-2009, 03:07 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation Just replaced HG and now it won't start
Ok so I just replaced my HG and now I'm not getting spark. It's really getting frustrating. I made sure that it was at TDC before installing the CPS. I'm getting 12V at the coils and to the igniter. I checked the ground for the coils and it is good. I'm not sure what else to do. Once I get it running then I can adjust the timing.
Also once this is done I've got to do it again for my other Supra.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 08-19-2009, 04:53 PM   #2
Kevin
double check EVERYTHING lol. cams and crank at tdc? cps inserted with the hole aligned with the notch (on the gears.) try taking a wires out and have a buddy crank it to see if you have spark. now plugs and wires?
Old 08-19-2009, 05:13 PM   #3
7mjunkie
7mjunkie is on a distinguished road
do you have a spare used cam sensor i need one for my 88 7mgte its my daily driver so i need to find one soon. my email is fleming.matt@rocketmail.com
7mjunkie is offline   Reply With Quote
Old 08-19-2009, 06:12 PM   #4
shiftysupra
shiftysupra's Avatar
shiftysupra is on a distinguished road
dont hijack this thread, fallow the forum rules and search the for sale section or post a thread for items wanted.
codes? what is your harness, a manual or auto? what sounds/does it do when you try and start it? need more info man to help you.
shiftysupra is offline   Reply With Quote
Old 08-20-2009, 09:22 PM   #5
robertsws
robertsws's Avatar
Smile
OK, I pulled the timing belt cover and the CPS and then double checked their alignment with TDC, Put it all back together and it started right up.
Of course now I have a really bad knock. Checked my valve clearances and 18 out of 24 are off anywhere from .001 to .003. I'm ordering new shims and then I will see if that took care of the knock.
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
Tags
cps, mhg, no spark
