Old 01-02-2010, 02:22 AM   #61
oregonjoe
oregonjoe's Avatar
Default Ghost connector.
What you appear to be holding is a ghost connection which I had on my 90 model. It did not go anywhere and I never connected it. It may be for turbo models or just a diag connector. I never found out what it was for but everything runs fine with out connected. Maybe for a Auto Tran since mine was manual?? Anyway wasn't VAC can as it had 3 terminals and was RED.
Old 01-02-2010, 02:31 AM   #62
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
ok thank you
cvbikeguy is offline   Reply With Quote
Old 01-02-2010, 02:47 AM   #63
I'm sure that's the case.
Old 03-22-2010, 02:23 AM   #64
connormcd88MKIII
connormcd88MKIII is on a distinguished road
Im in the middle of replacing my blown head gasket. These pictures are great. My #6 went too. Just wondering if you knew the torque settings when tightening the new gasket?
connormcd88MKIII is offline   Reply With Quote
Old 03-22-2010, 02:41 AM   #65
Bolts = 75ft. lbs.
Studs = 90ft. lbs.
If you're reusing the stockers check thoroughly for bad threads, pitting, and measure to make sure they're still within spec.
NOTE!!!! Torque specs change depending on what you're lubricating the friction points with (Head, washers and threads of the bolt). Those I've listed are for use when using a GOOD moly based grease. Don't forget to chase the block's threads too!!!!
Old 03-22-2010, 03:22 AM   #66
cvbikeguy
cvbikeguy's Avatar
Lol did my arp's at 85
Old 03-22-2010, 02:26 PM   #67
oregonjoe
oregonjoe's Avatar
Default Torque
Did my ARP studs to 90 with lube.
Depends on gasket. Metal?
I think stock was 55 but everyone now seems to go at least 70
Old 03-23-2010, 12:46 AM   #68
On studs I hope... that's a lot more than you want to torque bolts to.... unless they're just lubricated with 30 weight motor oil and not moly.
Old 03-23-2010, 01:58 AM   #69
907mge
907mge's Avatar
for anyones info, i found a strap wrench worked well to get the cam gears off on mine
Old 03-23-2010, 02:12 AM   #70
I just stick a socket on one of the bolts holding the back plate on with an extension on it. Gear turns, spoke stops at the socket and extension and you're done. Strap wrench would definitely work well if they have a larger one on hand.
Replace or Rebuild a 7mge cbrewster MKIII Supra 2 03-19-2009 10:20 PM
7MGE Engine Rebuild SilenceboneSupra MKIII Supra 1 10-23-2007 06:45 PM
PLEASE help newbee with engine rebuild canadian mole MKIII Supra 4 06-17-2007 01:01 AM
New Engine Or Rebuild Help ! ! ! ! ! DarkRaiderz MKIII Supra 5 01-23-2006 01:21 AM
