Old 08-11-2009, 04:28 PM   #1
scaggsj
scaggsj's Avatar
Default Blown Head Gasket
So I took my head to the machine shop Ive removed the cams, The machine shops going to check for cracks, put my new valve seals in, do a valve job and reseating valves, going to surface the head and do the cleaning.
Questions:
1.) Does any one know the tourqe for the installation of the cams?
2.) All that is going to run me about 210. usd does that sound fair. He usallly charges me 50, 60 bucks for cleaning checking and resurfaceing. The guys pretty good. Hes done all my head work just curious what other people have paid for this.
Old 08-12-2009, 02:10 AM   #2
Kevin
torque bearing caps (things that hole the cams) to 14ft-lb... make sure you do it in proper sequence
heres a link that may be useful
http://cygnusx1.net/Supra/Library/TS...aspx?S=EM&P=52
Old 08-12-2009, 03:13 AM   #3
scaggsj
scaggsj's Avatar
Thanks for the link Ive got to bookmark this, soon as college starts I can use alldata again which rocks but this looks as good.
Old 08-12-2009, 03:25 AM   #4
Kevin
here are a few other good bookmarks
Parts numbers refernce.
http://www.toyodiy.com/parts/q.html
good how-to's
http://www.supramania.com/forums/articles.php?c=158
http://gallery.sanitylapse.com/v/supra/
http://www.supras.com/06/techcenter/techtips.php
Old 08-12-2009, 03:41 AM   #5
scaggsj
scaggsj's Avatar
again thanks, Ill prob post some pics as soon as I get everything clean so far everything looks good not alot of ware anywhere.
Old 08-15-2009, 05:44 PM   #6
scaggsj
scaggsj's Avatar
Default Valve Covers repainted
Just some pics, My heads taken forever they head to take fourteen thousands off and theyre still doing the valve job hopefully next weeend ill have everything back together all the parts are here and mostly clean but I thought since I had the extra time why not paint the VCs I used High temp paint to paint them, 500f and for the accents I used acrylic Ill keep everyone informed if it dosent last. Also some pics of injectors after clean Ill post more pics as I finish every thing up try to get some of block and deffintly head when I get it back.
ID:	2224   Click image for larger version
ID:	2225   Click image for larger version
ID:	2226   Click image for larger version
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Adjusting Valve Shims Chambers MKIII Supra 6 02-09-2008 07:37 AM
stupied question on head removal suprabahamut MKIII Supra 18 07-02-2007 12:47 AM
