Old 08-05-2009, 05:38 AM   #1
scaggsj
scaggsj's Avatar
Default Overdrive off light stays on
Just bought this car and the O/d off light stays on, when you press the button the light does react until you take your hand off. Ive noticed that the shifter is loose does this sound like it could be the switch not being secured or is this the sign of a bigger problem. I was told maybe I should change fluid and filter for the auto tranny but even though I plan to do that anyway I find it hard to believe that it could affect this problem. Anyone else had this problem?
Oh its a 87 7MGE Auto stock everything.
Old 08-05-2009, 04:36 PM   #2
mirage83
Could be a bad O/D switch on the shifter. You'll want to pull the console panel where the shifter is and replace the shifter bushings (Toyota, cheap part to fix it), makes a world of difference if the shifter is showing side-to-side sloppiness. While you're in there take a look at the O/D wiring and maybe clean up the switch if you can get to it.
This is definately not a tranny problem, though like you said it wouldn't be a bad idea to have the fluid changed. BTW, you don't have a filter, just a pickup screen iirc.
Old 08-05-2009, 11:09 PM   #3
scaggsj
scaggsj's Avatar
Thanks, for your help. this is my first supra, Ive had three celicas but thats childs play compared to this car.
Old 08-06-2009, 01:51 PM   #4
mirage83
Get used to it. The MkIII tends to be very jealous of your time, attention, and money. Look at it as being the expensive mistress you never thought you could afford.
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
