Old 08-07-2005, 06:25 AM   #1
MWoz34
MWoz34 is on a distinguished road
I am just about to purchase my first car ever, a 1987 Toyota Supra. I put down my deposit today, and I am scheduled to pick her up on Monday. I have done serious research today about troublespots on Supra's, and I have discovered that the Head Gasket is the main problem. We drove the car and everything ran fine. NO warning signs of a possible head gasket problem. Still i am a little worried about the head gasket. Does anyone know a way to prevent the head gasket from blowing, and if you do, i would really appreciate it if you could let me know right away. Any advice given would be greatly appreciated.
Thank You Very Much.
MWoz34 is offline   Reply With Quote
Old 08-07-2005, 11:13 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
the only way to prevent it blowing is to buy a new one from toyota and ask them to torque it down properly lol
sorry but it will blow eventually
what i would do is save up the $$ for the new hg and bolts and get the head checked for warpage etc... clean surfaces new toyota hg and new toyota bolts torqued to 72ft lbs (or arp head studs torqued to 82ft lbs with arp moly lube) and do it before it blows... or when you see the very first symptoms...
temp spiking
overheating in traffic
overheating on boost
is just some symptoms
of course if you have these problems try the simple things first... radiator flush, water pump, radiator cap, thermostat
if it's from a dealer see if you can score some sort of warranty that covers the hg
Pics of my build.
Do a diagnostic first!
Old 08-07-2005, 07:45 PM   #3
MWoz34
How much will the head gasket cost altogether???
How much will the part cost, and how much will labor cost?
Should this problem prevent me from purchasing the car?
Old 08-07-2005, 09:12 PM   #4
SuperSupra86
SuperSupra86 is on a distinguished road
bolts 80-90$ i have seen
HKS Bead Metal Head Gasket TOYOTA Supra 1986.5-1992 (Engine Code: 7MG(T)E) Thickness (mm) 1.2 Bore (mm) 86 Compression Ratio - 140 ish
Labor....hella lot it took me two days work to take her apart and put her together 15 or so hours....probably around 65-85 bux an hour plus shop fees.....im not trained self taught so they probably faster but its really expensive..............My 1987 turbo targa top 5spd is the most fun car ever handles on rail....premium fuel gets pricey as well i buy octane booster.... its fun....i almost didn't and im glad i did
Who needs zoom zoom......I got turbo!!!
SuperSupra86 is offline   Reply With Quote
Old 08-08-2005, 10:03 AM   #5
Poodles
Poodles is on a distinguished road
I've seen about $3k to do the whole nine yards on taking the engine out, machining block and head, and doing the install because of all the labor. If you're good enough to pull the engine yourself and replace the headgasket yourself, you'll save a LOT of money I'd imagine...
Poodles is offline   Reply With Quote
Old 08-10-2005, 11:45 AM   #6
Guest
Guest
Posts: n/a
Supras dont normaly blow the head gasket unless ur gonna drive like a maniac.. all the time, yess they do have a problem with the head gasket but more so on the turbo models, u can pick up a HSK gasket for around $200 ausie dollas, this should prevent the head gasket from blowing for upyo around (estimate) 250,000 ks. thats if u drive like ur driving like ur in bathurst, on the last lap nd everyones infront of u. but i reckon ur pretty safe as far as gaskets go
Old 08-11-2005, 02:08 AM   #7
MWoz34
Well i have bought the car, and lets hope everything turns out ok. I'll say that the car is in excellent condition and it drove home perfectly. I am going to take it to our mechanic to have the torque changed to 75 lbs. ft.
New Supra OWNER. VooDoo MKIII Supra 4 03-12-2008 12:24 AM
New supra owner (not running) here What to do next Gengus MKIII Supra 1 11-12-2007 03:46 AM
Possible supra owner questions! Zanark MKIII Supra 2 08-24-2007 06:01 AM
New to this forum(not a supra owner though) Supra spotted in tucson. z33 DaRkNeSs Off Topic Forum 5 08-28-2006 11:16 AM
