#31 |
Funny you should revive this thread. I actually managed to fix the problem. What it ended up being were the injectors. I had a donor supra, so I swapped out the injectors and voila, problem was solved. My theory was that they were injectors for a turbo model in my NA model. I don't know if this will help you, but I would definitely check to see if the electrical resistance on your injectors are consistent for your model.
#32 |
Thanks a lot gettarobo!! if that turns out to be the solution, i will come and find you wherever you are, i will anoint your head with oil and wash your feet with my hair. LOL
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL! ![]() CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time FORD- Flipped Over, Rebuilt Dodge DODGE- Dirty Old Dust Gathering Engine I'd rather drive a Toyota, than push a ford. |
#33 |
I have a 1989 turbo with recent mild modifications, a slow work in progress. The car backfired badly a few weeks ago at speed, the check engine light came on and I had similar symptoms, would not rev above 4,000 rpms. Checked everything, changed TPS, etc., no luck. Finally found a simple cost free problem. The lower intercooler hose had come off, huge vacuum or pressure leak. Re-attached it and made sure it was secure, problem solved. One possibility. Hope this helps.
| ABS Problem? | rasclaat_98 | MKIII Supra | 6 | 12-13-2010 09:53 PM |
| speed sensor problem | nadircicek | Non-Generation Specific Questions | 8 | 10-09-2009 05:58 PM |
| another heater problem | nicnet | MKIII Supra | 16 | 12-05-2007 10:18 PM |
| found the problem | brs86supra | MKIII Supra | 0 | 05-02-2006 03:42 PM |
| Boost Problem, I Guess | nonstop213 | MKIII Supra | 0 | 02-23-2006 07:32 PM |
