Old 03-25-2011, 01:21 AM   #31
GettaRobo
GettaRobo is on a distinguished road
Funny you should revive this thread. I actually managed to fix the problem. What it ended up being were the injectors. I had a donor supra, so I swapped out the injectors and voila, problem was solved. My theory was that they were injectors for a turbo model in my NA model. I don't know if this will help you, but I would definitely check to see if the electrical resistance on your injectors are consistent for your model.
GettaRobo is offline   Reply With Quote
Old 03-25-2011, 02:14 AM   #32
El_supracabra
El_supracabra is on a distinguished road
Default God. Bless. YOU! but only if it works for me. :)
Thanks a lot gettarobo!! if that turns out to be the solution, i will come and find you wherever you are, i will anoint your head with oil and wash your feet with my hair. LOL
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 08-27-2014, 11:22 PM   #33
Stormin
Stormin is on a distinguished road
Thumbs up Possible Solution
I have a 1989 turbo with recent mild modifications, a slow work in progress. The car backfired badly a few weeks ago at speed, the check engine light came on and I had similar symptoms, would not rev above 4,000 rpms. Checked everything, changed TPS, etc., no luck. Finally found a simple cost free problem. The lower intercooler hose had come off, huge vacuum or pressure leak. Re-attached it and made sure it was secure, problem solved. One possibility. Hope this helps.
Stormin is offline   Reply With Quote
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
