Old 05-22-2009, 10:40 PM   #1
Tundo
Tundo is on a distinguished road
Default Need some help!
I converted my auto 7mge, to a 7mgte 5speed, Well the problem is that I noticed that I cannot find the clutch switch connector in the wiring anywhere. Does anyone know if/why there is no connector? I thought the car harnesses were all the same. Also if someone knows where it is, could they tell me that, thanks.
Tundo is offline   Reply With Quote
Old 05-22-2009, 11:23 PM   #2
86.5 7MGE
86.5 7MGE's Avatar
Thumbs up
From what I read in the other forums...I believe that the wiring harnesses are different.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 05-23-2009, 12:20 AM   #3
Tundo
I'm not talking about the engine harness, the car harness. If that's what you were thinking.
Old 05-23-2009, 01:11 AM   #4
86.5 7MGE
86.5 7MGE's Avatar
Are you referencing this? Inside the where the clutch goes...it should be around where the fuse box is and might even be taped up.
Name:	Clutch Switch connector.jpg
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 05-23-2009, 01:51 AM   #5
Tundo
The connectors that plug into those switches, I cannot find, idk if these pics will help.
Old 05-23-2009, 06:21 AM   #6
86.5 7MGE
86.5 7MGE's Avatar
Cool
I would look under the dash in the mess of wires to see if you can find the other end of it; also try looking on the side where the fuse box is. I sure that the wire would be under the dash some where. The CSS is used for your cruise control if it's not hooked in your just not goining to be able to engage your cruise control.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 05-23-2009, 07:54 AM   #7
Tundo
Yeah I ripped the Cruise control out about two years ago, it was broke anyways. Which one is the connector for the cruise control? thanks
Old 05-23-2009, 03:27 PM   #8
86.5 7MGE
86.5 7MGE's Avatar
Cool
They both are for the cruise control. What happens is that when you press the clutch it detects that the clutch is being pressed and turns off the cruise control. And the other detects when the clutch is in it's normal position (not pressed) and it allows you to turn on the cruise control. The CSS is the one in the back of the clutch. Hope this helped you out some what
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 05-23-2009, 03:36 PM   #9
Tundo
Wait a minute, to start the car the computer needs to know that the clutch is pressed in, so if these are both for the cruise control...I'm lost lol...
Old 05-23-2009, 03:39 PM   #10
86.5 7MGE
86.5 7MGE's Avatar
Thumbs up
My apologies, I ment the one that's in the back is for the cruise control and the other one in front is the one that you need to have connected.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
