Old 05-08-2009, 07:00 PM   #1
dunewarz
dunewarz is on a distinguished road
Default Supra running super advance....
My supra is acting really weird. I have a code 52 (knock), so I did a timing test. When I rev the engine the timing gets super advance. From what I know it should be getting retarted due to the knock sensor issue. Could anyone who has fixed the problem let me know how you fixed it. I would like some input before I start working on the vehicle to save some time and head ache.
Thank You
dunewarz is offline   Reply With Quote
Old 05-08-2009, 08:00 PM   #2
mirage83
It's almost a guarantee that your knock sensor wiring is messed up. That wiring tends to go bad far more often than the knock sensors themselves do. Toyota makes a rewire kit for that exact problem, or there are a couple of mods using coax which can use to fix it.
Old 05-08-2009, 10:07 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
As mirage83 said, more info here.
Old 05-08-2009, 10:27 PM   #4
mirage83
Thanks Bill. Knew I'd seen that mod before, but couldn't remember which site it was on.
Old 05-09-2009, 03:32 AM   #5
dunewarz
I'm not sure I understand what hes trying to do. He has the main middle wire and the net wire. He connects the middle wire to the knock sensor. Connects the net wire to ground.
But when he gets to the ECU he does what? Is he pretty much just connecting the ground wire to the knock sensor wire? Can't you just get a single strand electric wire and tap an extra electric wire on it to ground in the engine bay?
Could anyone explain to me a bit more about what he does when he gets to the ECU? Also I couldn't find the manual for the knock sensor wiring, does the knock sensor need to be grounded?
Thanks for the help....
Old 05-09-2009, 03:41 AM   #6
dunewarz
In my post I said my timing becomes advance instead of retarted, anyone have that issue?
MKIV Supra TT Daytime Running Lights?? MIX MKIV Supra 2 08-30-2007 02:52 AM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
87 Toy Supra N/A, Running on 4 Cylinders wilvelas MKIII Supra 5 04-24-2006 02:40 AM
Think my Supra is Super! scruffboy Non-Generation Specific Questions 2 09-21-2005 04:40 PM
