Old 04-24-2009, 09:53 PM   #1
Moses76
Moses76 is on a distinguished road
Default Swap or Mod for break rotors on 87 none turbo
Does anyone know a swap or Mod for break rotors on 87 none turbo? Although I'm making her into a turbo Just want that extra stopping power. Any help will be appreciated!
Moses76 is offline   Reply With Quote
Old 04-24-2009, 11:51 PM   #2
h8z2luze
h8z2luze's Avatar
ebay has cheap drilled and slotted rotors for the supras.
Old 04-25-2009, 01:48 AM   #3
mirage83
The only way to get a real difference in braking is to go to a Wilwood or similar upgrade brake kit with larger rotors and suitable-sized calipers & pads. Serious dollars, but other than just getting quality pads and rotors (which will help to some degree) that's about your only option.
Oh, and skip the drilled rotors, from Ebay or anywhere else. Good chance of them cracking long before they're worn out, completely wasting your money. Slotted is up to you, but get quality in any case. Brembo is good at a reasonable price. Cryo rotors are okay, but the science on them really being any better than regular rotors is still questionable.
Old 04-25-2009, 01:50 AM   #4
h8z2luze
h8z2luze's Avatar
Thanks for correcting me I didn't realize the cheaper ones cracked. Good to know.
Old 04-25-2009, 02:13 AM   #5
mirage83
Yeah, the drilled rotors may look sexy but they do tend to crack, so I really recommend staying away from them entirely. Additionally, since you're taking away metal when you drill you're reducing the ability of the rotor to deal with heat buildup.
You're much better off with a good set of regular rotors and good pads. Slotted will help braking somewhat in wet conditions and are a viable option as well. But either way quality will make a difference both in braking and in lifespan of use.
Cheap Na to turbo swap supraman121 MKIII Supra 0 12-07-2006 08:03 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
