Old 04-21-2009, 01:55 PM   #11
87mk111
87mk111's Avatar
I'll look into that as well, but I have a spare head, so I'll work on that first. I plan on getting the hks gasket and using the arp head studs. With that combo, the gasket should last for awhile, espaecially since I plan to only run like 7-9 psi.
Old 04-21-2009, 02:26 PM   #12
Kevin
why dont you drop a 7mgte right in there
Old 04-22-2009, 02:23 PM   #13
87mk111
87mk111's Avatar
I was planning on going with the arp studs and hks gasket when i do the head gasket. I'll look at the block/bottom end when i swap the heads.I can't really do that now because my supra is my daily driver right now until I fix my accord. I going to start with the head work tho, since i have the spare head laying around in the garage.
Old 04-22-2009, 02:25 PM   #14
87mk111
87mk111's Avatar
By the way. Which cams are better? Crower 264, or Crower 272?
Old 04-23-2009, 02:02 AM   #15
RedSupra87
RedSupra87 is on a distinguished road
why dont you just shop around for a 7mgte?
RedSupra''87''
RedSupra87 is offline   Reply With Quote
Old 04-25-2009, 03:32 AM   #16
SC Rydah
SC Rydah is on a distinguished road
Yeah the GTE is FAR cheaper than building a GE into a turbo motor. Do you know all the parts that make a GTE what it is as opposed to a GE? Crazy parts to make it reliable.
I suggest you find a 7MGTE, and swap your GE for it. MUCH LESS HEADACHE. I was gonna do the same thing, but I was told by numerous others who tried it to do the swap instead, but I have a 90. So the mounts for the 1JZ are there. I just have to worry about wiring and drivetrain.
SC Rydah is offline   Reply With Quote
Old 04-25-2009, 01:45 PM   #17
supradaddy0803
supradaddy0803's Avatar
The wiring for the 1JZ isn't that hard really as long as you take the time like I did and put in new harness plugs instead of soldering the connections for the four plugs you have to replace. I just bought some harness plugs that had enough pin holes to work and then bought the pins and did mine that way. As for the main engine harness you don't have to extend it you can always use the tuck like most people do it helps keep the integrity of the original harness.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 04-27-2009, 02:25 PM   #18
87mk111
87mk111's Avatar
Well, it will be a while before I could turbo the car or do a swap. I will be setting a side money whenever I can to do this this project. I will also have to find a second car before then, as the supra is my only car right now. If it looks like it might be cheaper to do a 7mgte swap, I just might.
Old 04-28-2009, 01:09 PM   #19
Tundo
Tundo is on a distinguished road
Originally Posted by 87mk111 View Post
nevermind, I was thinking it would cost around $2k. I guess I'll just turbo the 7mge. By the way, it's a 5 speed.
Buy a *7mgte*, unless you plan on buying everything exactly down to the needle, 7mge's don't have the oil sprayers in the block, trust me you want those. Other thing is, you will need to rebuild the engine if plan to turbo it, and usually that requires you to remove it, so why not swap it with a 7mgte.
Tundo is offline   Reply With Quote
Old 04-28-2009, 02:04 PM   #20
87mk111
87mk111's Avatar
Well, I'm trying to find a turbo block because of the oil sprayers. If I can find a block, I can pair it with the spare head I have, and basically build my own image. But If I have to, I will rebuild the block I have. By the way, will the crank have to be replaced, or is the stock one pretty beefy?
1jzgte swap questions flyboy13888 MKIII Supra 11 08-16-2007 05:26 PM
1jzgte swap noa324 MKIII Supra 4 03-07-2006 07:24 PM
