Old 07-26-2005, 05:01 PM   #1
intenseneal
Guest
Posts: n/a
Does anyone konw what stock fuel pressure should be on the MKIII? I just upgraded my fuel sytem with a 2JZ fuel pump a mechanical fuel press. gauge and bosh ajustable regulator. The Toyota repair says stock preesure should be 30-40 psi. Is that at idea or under boost. Any info will greatly help.
Old 07-27-2005, 01:55 PM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yep the stock fuel pressure should be 35-40psi... this is at idle.. under boost it should rise...
also please don't double post, it won't get your questions answered any faster
GL
Pics of my build.
Do a diagnostic first!
Old 07-27-2005, 04:47 PM   #3
Intenseneal
Guest
Posts: n/a
Thanks for the info it hepled out alot. Sorry about the double post, did it on accedent. Also how much should i I raise fuel pressure? I am runing 11psi of boost and still have the stock 440cc injectors.
Old 07-28-2005, 01:53 PM   #4
suprra_girl
7M POWAH! ;)
well... really at those levels the stock ecu should be able to still control it just fine
take it for a boost and see what the fuel pressure gets up to and if it holds
i think under boost she'll go to 50ish psi?? not overly sure on a stockish engine
Pics of my build.
Old 07-28-2005, 05:16 PM   #5
Guest
Guest
Posts: n/a
Thanx everyone I found the problem. I set fuel pressure with the vacum line hooked up and that caused fuel pressure for sky rocket under boost ( 80psi). Fuel pressure holds right at 45psi under boost. Now I have enough fuel to feed the fire, at least untill I get a HKS FCD. 15 psi here I come.
P.S. the car is getting really quick. 265hp @ 9psi & 260 torque. Not bad for a lightly BPUed MKIII.
Old 07-29-2005, 01:37 PM   #6
suprra_girl
7M POWAH! ;)
congratulations on the #'s
but do be careful... do you have a wideband 02?
to be honest i don't know what your fuel pressure should be under boost...
maybe you should get it dyno'd to ensure you are getting correct fueling.... the last thing i would want is for your engine to detonate
can anyone else chime in on fp?
Pics of my build.
Old 08-10-2005, 09:53 PM   #7
Intenseneal
Guest
Posts: n/a
No I dont have a wideband O2. I do work for a tuning shop with a dyno and a wideband and can use it when ever I want to. On my last runs @9 psi I saw 12.8 to 1 air fuel ratio. Almost on the lean side, that is my I felt I needed a bump in fuel pressure 45psi. I haven't had the chance to get the dyno since the fuel increase, but look for more threads on this in the near future.
Old 08-10-2005, 09:55 PM   #8
Intnenseneal
Guest
Posts: n/a
Also 45 psi is fuel pressure under boost, at idle I have 35 psi. Wideband monitoring is need though to keep an eye on things.
Old 03-18-2006, 04:59 AM   #9
djalkyd
djalkyd's Avatar
djalkyd is on a distinguished road
any updates on this? i am interested in your outcome because i just upgraded to a walboro 255 fuel pump and i checked mine at idle and i got 34 at idle with the vacuum line on and 38 with it off. pretty close to what the manual says.
i haven't checked it under boost yet so i am wanting to see what an average out come under boost would be.
djalkyd is offline   Reply With Quote
Fuel injector question kwayne MKIII Supra 3 06-12-2008 01:46 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
How can I check my fuel pressure? Busted Knuckles MKIII Supra 6 04-10-2008 04:19 AM
fuel pressure guage FullOfProblemsMKIII MKIII Supra 3 01-21-2008 11:52 PM
Fuel pressure regulator Supraman MKIII Supra 1 07-31-2006 03:03 AM
