Old 07-23-2005, 01:00 AM   #1
azzurro
azzurro is on a distinguished road
Hey Supra Foe im new to the forum!! its a pleasure to be a part of it all From Adeliade, SA.
I have a problem with my MA40! Hope someone can shed some light!!
Im running a 1989 JDM MA40. 2L TT 6pot.
Mods so far...
Reco stock turbos (done about 6 months ago by Adelaide Turbos)
HKS pod (on car when imported)
HKS Catbak (on car when imported)
HKS S/S Blow off (on car when imported)
Larger Front section pipe ( Just installed)
New Custom larger FMIC. (just installed) B)
Manual controller runs 12-14psi max
Stock Head, Internals, and ECU
Just Dynoed the car at 144.5 rwKw. - The fuel ratios were so high (ritch) off the scale.
Im guessing theres fair few kw lost here :unsure:
Should I be doing a Boost / Vacume leak test??? or look at idol or ecu settings??
Any feed back would be appreciated!!
Cheers
Frank
Azzuro MA40 mkIII Supra
Cheers
Azzurro
1989 MK III 1G SUPRA
HKS Intake, HKS Exhuast, HKS SS BOV, Custom FMIC, Front Pipe, Reco Turbos, 19" Zanetties, 45mm Lowered Coils,
Dyno 156rwkw @ 10-14psi, Stock internals and EcU
Also NEW MA70 car yet to discover wat its on about
azzurro is offline   Reply With Quote
Old 07-23-2005, 01:32 AM   #2
SuperSupra86
SuperSupra86 is on a distinguished road
Remember that boosting makes your fuel air ratio much more rich, but if something is wrong Well i would test my ecu first because if im not mistaking that helps control fuel/air ratio....thats what i think it sounds like....maybe it could be the boost, but boost just force inducts more air....so if your getting too much fuel in there than that wouldn't make sense...
thats my 2 cents...i'm one of the newer guys to supras so i would wait for Suprra Girl, monkihead, king diamond, etc... to weigh in they have more experience...
Who needs zoom zoom......I got turbo!!!
SuperSupra86 is offline   Reply With Quote
Old 07-23-2005, 08:11 AM   #3
you say the numbers are high.... that would suggest the opposite actually
you would be running lean
rich would be low numbers
what was the exact a/f ratio?
also your mk3 is a GA70 89 supra ma40 is the mk1 celica i believe heh
Old 07-24-2005, 01:46 AM   #4
azzurro
Hey thanks for your info and repy
Yeah soz there its way to ritch i mis read the dyno how the scales are set. The dyno says it went too low off the scale im not sure of the number. i might have to scan the sheet and post that. One other thing i noticed is that at peak power the boost dropped off to a flat curv at 10psi. I will be trying a boost leak test and then i will know if its the ecu. Hopefully we can sort this out cos i dunno if the 145 mark is all the car has or if it has more in her!
Cheers
Frank (azzurro)
Cheers
Azzurro
Old 07-24-2005, 02:23 PM   #5
hmmm you could have a boost leak... generally if it's real bad you will not be able to get on boost properly and it won't idle the best and it will also poke black/grey smoke out the exhaust
check all your intercooler pipes.. specially the one off the turbo as that is a common culprit
