Old 02-10-2009, 02:24 AM   #1
supraspaz
supraspaz is on a distinguished road
Exclamation smoke after rebuild of top end
ok new to the world of supra (more experienced in chevy n triumph ) so usual suspects of bhg. she is a 87 7m-ge 5-speed - well tear down n rebuild of top end in three days. ( when i get on a project i keep on it , sometimes bad ) just hopeing this is not one of the times it's bad. anywho cleaned everything really really really good (parts washer hehehe ) replaced all gaskets except cam seals n egr box ( cover with 8 bolts ) stock gasket kit was used ... but after start up all was well ... on test drive the familar smoke was back but not as bad ... is this a possibality of a warpped head ? ( no it was not sent to a shop to be re-worked ) is their anything else that would cause smoke in the exhaust like that ?
sorry for odd n maybe simple questions ... just n unknown territory
thanks
supraspaz is offline   Reply With Quote
Old 02-10-2009, 03:50 AM   #2
SilverBullet05
SilverBullet05's Avatar
SilverBullet05 is on a distinguished road
Default Smoke
i would have t osay you probablly should have taken the head to a shop to get lapped and atleast taken a hone stone to the block if it isnt able to go to a shop. it could be warped head possiblly the block, but it kinda sounds like the rings are a litl worn out. a little more info on the motor would be nice. Like miles on it before the rebuild would help. just my piece of mind. good luck.
ALL BOOST NO JUICE!
In need of some 7mge parts, let me know what you got.
SilverBullet05 is offline   Reply With Quote
Old 02-10-2009, 10:53 PM   #3
supraspaz
Post tonight
well tonight when i'm workin on it i'll get the info n if i can i will post the pic's of the 1st rebuild. lol hopefully you can get n idea of what it looks like. wish me luck ... when i rip it apart again oh im gonna send the head out this time to have it re-worked.
Old 02-12-2009, 08:20 AM   #4
tsupranami
tsupranami's Avatar
tsupranami is on a distinguished road
Does it puff a big cloud on startup? Trailing throttle? If so, old, hard valve stem seals and worn rings are most likely culprits. Mine was mainly valve stem seals. I had over 200k miles, and cylinders looked like new, rings were worn but not past spec, still had over 160psi compression. But it would paint a nice film of oil on the rear bumper after a few hundred miles. Yuk. I had my head surfaced and new stem seals installed for $200, including reassembly. I didn't let them touch the valves or seats, as they were sealing just fine. They just removed them , then cleaned and replaced them. Then I installed a MHG w/ ARP studs and turned up the boost. Smoke has been gone ever since and no more oily bumper.
tsupranami is offline   Reply With Quote
Old 02-14-2009, 08:31 PM   #5
supraspaz
Talking all is good
well after using mass amounts of solvent. in the intake too i might add. i drove the car for about 15 minutes n then wow all was gone except a light blue (probablly the valve stem seals) puff on hard excel. runs smooth n no other signs of other issues (yet). will probablly do a mhg after i save n have some other small projects tackled on her. hopefully i can get some advice on the rebuild with mhg from everyone if possible. also if still waiting on the photos ... just a little longer ... i can't find my memory card. lol thanks again!
oh any good places to get parts or web sites? just curious
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
To rebuild or not to rebuild that is the question 88supraturbo5speed Non-Generation Specific Questions 6 04-21-2008 04:05 PM
Why is this smoke coming from the turbo? Turbotuner2.3 MKIII Supra 3 11-12-2007 03:30 PM
Oil n smoke from turbo wolfen Non-Generation Specific Questions 0 10-30-2005 12:27 AM
