Old 01-27-2009, 04:31 PM   #1
89whtsupra
89whtsupra is on a distinguished road
Question TPS removal
Could anyone tell me how to remove the TPS on a MKIII. Do you just need to remove the 2 screws or do you have remove the throttle body and more?
89whtsupra is offline   Reply With Quote
Old 01-28-2009, 07:48 AM   #2
Just the 2 screws and the harness plug
Old 01-28-2009, 09:24 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Don’t forget you’ll need to set it up again when you reinstall it Link Unfortunately it’s a sealed unit; to gain access to the PCB inside you will need to partially destroy the clips holding the casing together. Also make sure you locate it properly when you reinstall it on to the throttle body, from memory I think there are some lugs on the throttle butterfly valve shaft that need to be engaged carefully. I didn’t take mine apart I only reset it.
engine removal mizuboi MKIII Supra 11 06-10-2011 06:25 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Fuse Removal + Nice Supra Pic jdbones Non-Generation Specific Questions 0 01-28-2008 01:01 AM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
