Old 01-24-2009, 04:19 AM   #1
3.0trd
3.0trd is on a distinguished road
Default warning light?
hey, sorry to bother you guys with this, but I'm starting to get worried. Aaaaaaall the way to the left of the gauge cluster, there is an orange icon, I can only describe as a birdcage. it used to flash for a second when I got hot into a corner, then go off when I got back straight. It stays on all the time now, and I really have no idea what it means...
Cometic MHG, ARP studs, H&R lowering springs
3.0trd is offline   Reply With Quote
Old 01-24-2009, 07:18 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Birdcage= Low Coolant Level. The pic is supposed to look like a radiator. The sensor for it is in the bottom of the overflow reservoir, so make sure you add coolant there too when you check your coolant levels.
Old 01-25-2009, 05:58 AM   #3
3.0trd
thanks man, that has been bothering the hell out of me. I check my radiator pretty often, but usually overlook the overflow bottle.
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Engine light and warning light on. Chomper MKIV Supra 11 07-18-2008 11:44 AM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
