Old 01-20-2009, 07:42 PM   #1
spudz29212MKIII
spudz29212MKIII's Avatar
Default Noisy Valves
Hey guys, im having a issue with some noisy valves. I did the ole broom stick trick and the noise is loudest on the exhaust cam side. I forgot which one its technically called but im guessing its a tap, or tappet kinda like a bunch of marbles in a can.
There is no noise on decel or accel but lately I have been hearing it slightly at the start of accel. I have a turbo and my boost gauge is showing a slight vacuum leak at normal speed then when I release the pedal its a quick downward flick to 20hg. Thought this may be sticky valves so I did a one day pedal to the metal crankcase seafoam treatment (which did good in other areas and also ive never seen such horrible sludge come out when I drained it) but I had no luck with solving the noise.
Any ideas on wtf is going on? Clearence? Help is much appreciated thanks.
Zach
Old 01-20-2009, 07:52 PM   #2
CyFi6
Most likely a valve lash issue. You can pull the valve cover off and check the clearances and then see what you need from there. Doing the actual adjustment is pretty time consuming (it uses shims so you have to replace each shim with the correct size)
Old 01-21-2009, 07:09 PM   #3
spudz29212MKIII
Im still learning so hang with me, upon my research im still slightly confused about valve lash/lashing from the plethora of explanations on different vehicles.
Could someone please elaborate? I know about shims, but lash? Is that like something loose like a bolt? I find it easier to understand comming from fellow MKIII owners. Thanks
Zach
Old 01-21-2009, 07:46 PM   #4
CyFi6
lash is just another word for clearance. adjusting valve lash is the same thing as adjusting valve clearance. You have to go in there with a feeler gauge and measure how much clearance you have, then you have to remove the cams and shims, measure what size shim was in there, calculate how much clearance was in there and then you can figure out what size shim you now need. dows that make sense?
MK3 TSRM On-Line
Check that out.
Old 01-21-2009, 08:14 PM   #5
spudz29212MKIII
yea that does, and ive read about it in the TSRM before and it just sounds like a pain in the ass with all those valves.
Zach
Old 01-22-2009, 03:37 AM   #6
CyFi6
Oh its a real pain in the ass. But the thing is im sure you will find many of them are already in spec and very close, so you wont need to mess with a lot of them.
about valves cyanide-is-a-way-out MKIII Supra 2 10-03-2007 03:08 PM
Valves, Cams,& the works carfanatic89 MKIII Supra 6 06-06-2007 04:02 AM
1jz valves XTREMESUPRA MKIII Supra 0 01-17-2007 09:49 PM
