Old 01-13-2009, 08:23 PM   #1
Animosity
Animosity's Avatar
Animosity is on a distinguished road
Default Diagnosis check
Hey all.
My car has been running rather sloppy lately so I decided to do the diagnosis. I came up with Codes 14, 31, 41 and 51.
I was wondering if anyone could tell me what the codes meant and how to help solve the problems!
Help is appreciated.
Animosity
Animosity is offline   Reply With Quote
Old 01-13-2009, 11:41 PM   #2
pln
pln is on a distinguished road
Thats a lot of errors.. what happened? seems to be AFM.ignition.ac problem. TPS
look here
http://www.toyota-supra.info/forums/...s-problem.html
JE,RPS-Max,MAPECU2,ARP,EIBACH-PRO,PTE-550cc,WALBRO,GT3582r,INNOVATE
pln is offline   Reply With Quote
Old 01-14-2009, 01:06 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
Let's see.....
Code 14 - Ignition signal - No 'IGF' signal to ECU 6 - 8 times in succession.
Code 31 - Air Flow Meter Signal - Open circuit in VC signal or short circuit between VS and E2 when idle contacts are open.
Code 41 - Throttle Position Sensor Signal - Open or short circuit in throttle position sensor signal.
Code 51 - Switch Signal - No 'IDL' signal, 'NSW' signal, or 'A/C' signal to ECU with terminals E1 and TE1 shorted.
If all this came on at once, this looks like a pretty bad systems failure. You need to check the wire harness for damage. I'd concentrate from where the harness comes out of the firewall to where it wraps around to the front of the engine.
Old 01-14-2009, 01:07 AM   #4
Animosity
Animosity's Avatar
Ah yes i removed the A/C because it was broken anyway. I don't know if it all came on at once becuase i just learned about performing a diagnosis today. And as for the wire harness that would be a nightmare for me. I'm not very handy with electonics =/
Animosity
1987 supra turbo check engine lights kidthunder650 MKIII Supra 2 03-15-2007 01:34 AM
5m-ge check connectors tonster MKII Supra 2 04-08-2006 06:54 PM
Check engine codes BossHogg MKIII Supra 3 03-17-2006 12:14 AM
