Old 01-12-2009, 02:15 AM   #1
suprabahamut
Default Idle problem
After the engine has warmed up for about 10 minutes it starts to act up. At red lights or when I stop it idles down to 500 rpms and some times turns off, it lugs really bad most of the time. It runs fine after I take off and driving, it is only when it idles. I have to usually keep the gas pedal down to keep it from turning off. Someone please help any advice is good!
Old 01-12-2009, 01:27 PM   #2
Chambers
Chambers's Avatar
Check the plug on the ISC, if its loose then it could cause that, but for reference check page 4 of this page http://www.swaqvalley.com/TSRM/03_EM.pdf, it will direct you to the info for checking for not idling correctly. Hopefully it will help you, good luck.
"Stuck in the 80's"
Old 01-28-2009, 02:23 AM   #3
suprabahamut
Thanks for the information. I have 1 more question can you use carburetor cleaner spray on the valve? I usually clean EGR's with it, but I wanted to ask if it would damage anything.
need help with 7mgte idle problem MAG.net MKIII Supra 4 09-06-2007 06:10 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
