#1 |
hte plugs whats that?
im putting bosh platnim in my car |
#2 |
typo "the" not "hte"
#3 |
ok man i changed all plugs and took a tooth brush and carb cleaner to all my intake and boost pipes. car runs like a champ now yay!
now go forth and change em plugs lol
#4 |
ok... that did not work either. im still having the same problem... somone plz help. if you dont know what im talking about look at my earlyer posts on this thread.
#5 |
I have a very similer problem going on with my 87 supra turbo, i found out after replacing spark plugs fuel regulator .... that i had a plugged strainer on the fuel pump in the fuel tank and plugged fuel filter which restrict fuel pressure due to the rust in the fuel tank. The fuel pump was working extra hard to pump through the rusty strainer. There is a drain plug in the center of your fuel tank try to empty some of the gas in your tank and see if it comes out clean or not.
Iam curious to know if your car has the same problem as my car did. Good luck.
Andy |
#6 |
CODES
this might be news to you but you car is trying to tell you what is wrong . the check engine light is a Tool , when you check this tool it blinks the light like a morse code signal http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
300+ RW HP Dyno run, jdm,mod turbo,3"exh,electfan,greddyboost Blown HeadGasket info My Supra KiXGaS |
#7 |
ok guys thanks but any theorys on how this only happens when it rains? maby my mass air flow sensor becomes expanded and locked in place?
i also know i have a boost leak.. but its on the exaust side. the downpipe is leaking. and i will replace that verry soon. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| my supra acting CRAZY help!! | mjmendoza | MKIII Supra | 7 | 05-09-2007 10:59 PM |
| Driving Bacwards in Australia | mrnickleye | Off Topic Forum | 5 | 10-09-2006 04:42 PM |
| 1988 Supra turbo with serious issues HELP! | chrish6323 | MKIII Supra | 4 | 09-26-2006 10:02 AM |
| While Driving... | burton51m | Off Topic Forum | 20 | 08-30-2006 09:29 PM |
| damn air going crazy again | sd88supra | MKIII Supra | 1 | 02-23-2006 04:12 PM |
