Old 01-07-2009, 01:08 AM   #1
sprigmo1
sprigmo1's Avatar
sprigmo1 is on a distinguished road
Default Lipp Fuel Rail Problem
I purchased a set of PTE Delphi 780cc Injectors for my 1992 Toyota Supra Turbo, and I cant for the life of me get them to not leak after installing them in my LIPP Fuel Rail. Any suggestions??
" It Ain't Eazy Being Me"
1992 Supra /TSW 618 Rims/Goodridge Brake Lines/Powerslot Rotors/Eibach Springs/Tokico/KYB Struts/ST Sway Bars/Cusco Strut Bars/Targa Bars/RPS Clutch/C's Shifter/Aero.AFPR/RC 560cc Inj/Walbro Fuel Pumps/Lexus AFM/HKS Timing Gears/K&N Intake/HPF Intercooler/Greddy BOV/Turbonetics 60-1 CT26/CSF 53mm RAD /Apexi S-AFC /Apexi AVC-R /Apexi N1Exhaust/RT DP/RT Cat/Jegs Catch Can/Greddy TT/Blitz Boost/EGT Guage/Blitz Peek Hold Device/Lotek Dual A-Pillar Pod/AEM UEGO WB
sprigmo1 is offline   Reply With Quote
Old 01-09-2009, 12:40 AM   #2
dannydavi
dannydavi's Avatar
umm.. not to familiar with those.. is it leaking from the injectors or the rail itself? and if injectors, is it leaking from all of them?
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 02-24-2009, 02:20 AM   #3
sprigmo1
sprigmo1's Avatar
Leaking from the o-ring side. Just #6!!
Old 02-26-2009, 06:03 AM   #4
tsupranami
tsupranami's Avatar
tsupranami is on a distinguished road
You've replaced the o-ring, correct? If they go in wrong even once they'll leak 4ever. Are you using OEM Toyota o-rings/seals or aftermarket? I've found the aftermarket ones run a hair smaller, so I soak them in gas for an hour or two so they swell up and soften a little before I install them.
89 Turbo Targa 5spd, 18x10 w/275/35/18, 18x9 w/245/40/18, Brembo CD rotors, Hawk pads, SS lines, HKS coilovers, ST sways, 1 pc. AL DS, V3 shifter, RPSmax PP w/HPF ferramic disk, custom crank, Eagle Rods, JE pistons, Ferrea valves, BC 264 cams, Fidanza cam gears, Walbro FP, AFPR, RC660 inj., Blitz SUS, Lexus AFM, SP 47trim CT26, HKS SSQ BOV, 2.5" AL IC pipes/FMIC, Lipp turbo elbow, RT DP, Greddy SP catback, HKS FCD, AEM Uego WB, Apex'i SAFC, Apex'i AVCR, EGT, Fluidyne AL rad, Flexalite fans.
tsupranami is offline   Reply With Quote
fuel rail G-string MKIII Supra 6 02-15-2011 02:40 AM
fuel pressure boost32 Non-Generation Specific Questions 1 08-10-2008 10:19 PM
Problem with fuel injectors! teedoff00 MKIII Supra 3 07-30-2008 05:03 AM
1980 Supra Fuel pump problem Zebian2 Non-Generation Specific Questions 2 11-20-2005 03:21 AM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
