Old 11-10-2008, 07:53 AM   #1
Serge
Serge is on a distinguished road
Default 7MGE Engine Temperature
Hi !
When I first start cold engine is that normal that engine temperature gauge goes into red sector for a few seconds and then drops into middle part of the scale?
Thank you!
Serge is offline   Reply With Quote
Old 11-11-2008, 07:28 AM   #2
igosaur
igosaur's Avatar
igosaur is on a distinguished road
I'm no expert but it sounds as if you have a stiff thermostat that has to get really hot before it opens. Once it opens of course the engine cools down straight away.
I'd try changing that first and see if it does the trick.
1989 3.0i 7MGE Auto RHD called Milly (Well, I have children)
www.atheistforums.org
igosaur is offline   Reply With Quote
Old 11-11-2008, 09:57 PM   #3
CyFi6
Sounds like you are saying when you initially start it, meaning not having time to warm at all? If so i would suspect the gauge/gauge wiring/temp sender.
Old 11-12-2008, 03:14 AM   #4
Serge
I have replaced the thermostat with 180* offset and the problem is gone.
Thank you!
Old 11-12-2008, 07:03 AM   #5
CyFi6
you should be running a 190 degree!
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
1JZ-GTE Engine with 7mge Stock Fuel Pump joolhamdi MKIII Supra 1 06-10-2006 10:29 AM
Engine swap 5mge for 7mge eternal genome MKII Supra 12 03-04-2006 09:20 PM
