Old 10-18-2008, 03:58 PM   #1
trevor217
trevor217 is on a distinguished road
Default Need a 14mm allen head bolt for valve cover
I took one of my 4 bolts from the 'No.3 Cylinder Head cover' out to get a set of gaskets to fix the problem i'm having with oil getting into the spark plug wells. Anyway, I lost the bolt, and was hoping maybe someone here has a spare? Or if not, is there something that can be used in place of it? I'll keep looking for it, but something tells me I'm not going to find it.
Thanks!
Trevor
trevor217 is offline   Reply With Quote
Old 10-18-2008, 04:54 PM   #2
trevor217
Went ahead and ordered one thru Toyota. Guy actually seemed to know what I was talking about! Came to $6.12. Not in till Wednesday, and with my luck I'll find it just before I leave to pick it up!
Trev
Old 10-21-2008, 11:11 PM   #3
dannydavi
dannydavi's Avatar
nice, thanks for the update. What gaskets did you end up purchasing? did you go with those oil plug gaskets or w/e?
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 10-22-2008, 12:00 AM   #4
trevor217
I found gaskets at Napa that should do the trick, I'll get part numbers (and results of the fix) when I pick everything up tomorrow!
Trevor
Old 10-30-2008, 02:50 PM   #5
trevor217
Default Update
I finally received the plug I ordered from Toyota. It took about a week longer than it was supposed to, but it arrived. I stopped at NAPA and picked up oil drain plug gaskets--I didn't get any part numbers, just use common sense. The gaskets I got were not exactly the size of the plugs, slightly bigger. As long as it makes a good seal under the plug you should be fine. It worked like a charm! I've ran it a couple times since fixing it and I don't see any oil leaks yet. A handy trick too: if you don't have a 14mm allen key, take a bolt with a 14 mm head, add a couple nuts to the bolt and tighten them on. Use the bolt as an allen key, just put the head of the bolt in the plug and turn it with a wrench. Worked great for me!
Thanks for everones help, and a big thanks to IHateHacks for posting this incredibly cheap, effective fix!
Trevor
are arp head stud same as bolt 88Tsupra Shops & Part Reviews 4 03-11-2007 02:43 AM
Head Bolt Retorquing Benesesso MKIII Supra 8 11-07-2006 03:49 PM
Head bolt torque kjhsupra Non-Generation Specific Questions 3 04-06-2006 09:19 AM
ARP head bolt torque Intenseneal MKIII Supra 2 08-31-2005 10:08 PM
