Old 10-16-2008, 10:06 PM   #1
bmc52387
bmc52387 is on a distinguished road
Default Replacing rear pinion seal
I need to replace my pinion seal on my rear diff. Any pointers? I have the pinion seal and side differential seals ordered.
bmc52387 is offline   Reply With Quote
Old 10-18-2008, 11:13 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
If you haven't done so yet, get the http://www.toyota-supra.info/forums/...9950-tsrm.html
I suggest you get access to air tools, especially a good impact wrench. The pinion flange bolt is a serious PITA without one. The factory torque setting is 134 ft-lbs. And yours has been on there for at least 13 years. It will not come off easily. Did you get a new spacer/crush sleeve? These are also suppose to be replaced when the pinion nut is removed. This guy is important to set the proper pre-load on the pinion bearings. Some shade-tree mechanics go ahead and re-use the old one, but most professionals say it is a No-No, and will lead to quick failure of the pinion bearings. I say, replacing it is cheap insurance. For the rest, follow the TSRM.
P.S. Air tools only to remove. Use a torque wrench to reassemble.
Rear Main Seal mkiiisupra MKIII Supra 3 09-28-2007 02:31 PM
need help replacing 89 supra front and rear brake pads 89supra323 MKIII Supra 16 05-25-2007 12:43 AM
Replacing rear hatch lifts Staceman MKIII Supra 4 12-07-2006 02:50 AM
rear seal blown frankie_lala MKIII Supra 2 09-02-2005 06:12 AM
