Old 09-26-2008, 08:55 PM   #1
daluxsrt4
daluxsrt4 is on a distinguished road
can i take it to a dealer to scan it? its not obd2 so my scanner wont work.
daluxsrt4 is offline   Reply With Quote
Old 09-26-2008, 09:07 PM   #2
Chambers
Chambers's Avatar
On the right side wheel well in the engine bay check to make sure the fuel pump relay is plugged in correctly.
It may also be any of many sensors, check the codes, check the TSRM on how to do check them.
A dealer may check your codes for free but I guarantee they will try to get you to let them work on it.
Good luck.
"Stuck in the 80's"
Old 09-27-2008, 02:05 AM   #3
Busted Knuckles
Busted Knuckles's Avatar
daluxsrt4, get a Haynes book for less than $20, and i has the instructions to short two terminals on the diagnostic connector under the hood to blink the trouble codes on the check engine light.
FWIW, it sounds like it is starving for gas. This could be a bad filter, regulator, pump, or clogged injectors. Of course, it is hard to diagnose from a forum post. Good Luck!
Old 09-27-2008, 02:49 AM   #4
daluxsrt4
pulled the plugs tonight and changed em. the plugs were totally trashed. while pulling the second to first wires out the electrode pulled outta the wire. i left that wire unplugged and drove around and it did the same thing with it unplugged. gonna grab some new wires and see if it fixes it.
Old 09-28-2008, 07:14 PM   #5
daluxsrt4
plugs didn't help. Still doesnt run like its suppost to. I'm working on the fuel pump and relay right now and ill let you know how that works out
Old 09-28-2008, 07:45 PM   #6
daluxsrt4
so ive just discovered it a bitch to get to my fuel filter so im not gunna waste my time until i check the codes does n e one know what two terminals i short to get the check engine light to blink and give me the code?!?!?!? thanxx
Old 09-28-2008, 10:00 PM   #7
mrnickleye
mrnickleye's Avatar
Thumbs up Advice for all
You MUST read all the threads in the FAQs section to learn about your car. It sounds like you want to work on it yourself, so educate yourself.
When you just ask for info, the answers you get may be WRONG. Then you may follow that advice, and PAY $$ for doing what a NON educated writer has offered.
READ the FAQ section, and all the sticky threads in each section before touching a tool.
http://www.toyota-supra.info/forums/...iagnostic.html
