Old 09-17-2008, 03:20 AM   #1
mkiiisupra
Default Ign Switch Signal for Elec. Fans
Trying to figure out where to wire in a ign switch signal for my perma-cool temperature switch so it will only turn on fans with the key in the ON posistion.
Looked around alot and cant really find where to wire into any help would be appreciated. Wiring diagrams have me scratching my head heh
1990 Toyota Supra Turbo A/T
Old 09-17-2008, 02:49 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Well, I know on most vehicles windshield washer motors are only on when the key is in the on position (dunno about the supra). You could use a volt meter and test the voltage between the various wires there and a chassis ground to find one that's only powered when the key is on. Using a tap splice you could then run straight to what you need powered, as long as it is just a low amp signal.
If you need to draw current from this line, again use a tap splice and run a wire to the coil side of a relay of proper amperage. Run another wire from the other coil contact to a chassis ground. Then run another wire (with a fuse) from a 12V power source (battery or fuse box) to the contact side of the relay, and then a wire from the remaining contact to the power input on your fan switch. This way you draw very little power on the windshield washer motor circuit, but only allow the fans to work when the key is in the on position.
Old 03-13-2009, 05:00 PM   #3
SilenceboneSupra
SilenceboneSupra is on a distinguished road
Sorry to bump this thread to but you can use a relay XD
SilenceboneSupra is offline   Reply With Quote
Master Window Switch? Supra_Nubus MKIII Supra 2 04-09-2008 01:49 AM
No Signal to Fuel Injector ithinkitwassumthini8 MKIII Supra 3 09-12-2006 06:35 AM
Faulty Headlight Switch... please help! MusicNazi525 MKIII Supra 4 10-30-2005 12:31 AM
