Old 09-17-2008, 01:06 PM   #11
Chambers
Chambers's Avatar
Well sorry to say, I do not have the skill or capability to weld aluminum at this time. If you need any help in designing it, I do have the ability to make technical drawing that any welding shop will be able to follow.
I would just need to know some dimensions of the aluminum stock your going to use and some of your engine bay dimensions, I do have a stock turbo manifold to get the dims of the runners and bolt holes from. If you want me to help design it send me a pm and I will send you my e-mail for dimensions and pictures.
Good luck.
"Stuck in the 80's"
Old 09-18-2008, 07:29 PM   #12
supravan
supravan's Avatar
supravan is on a distinguished road
i dont no what size of pipe to use and ill send you want ever you need to design it four me, just let me know what all you need and ill get it to you asap
supravan
supravan is offline   Reply With Quote
Old 09-18-2008, 10:11 PM   #13
Chambers
Chambers's Avatar
Ok, sorry for the wait, I have the lower intake manifold. From that I will start building the concept on SolidWorks. I will talk to a few people who have made the FFIM before and ask them on what grade metal and what thicknesses to make it out of. When I get an idea on the metal I will let you know.
By the way, that van looks freaking sweet!
"Stuck in the 80's"
Old 09-19-2008, 01:45 AM   #14
supravan
supravan's Avatar
wouldnt it be the same thickness as the runners are on the lower part just curious, and when your able to design it could you make it to wear its as close to the block as possible and where the throttle body would come out where the alternator bolts up, you no in between the 7M-GTE on the time cover and the alternator pulley and it just needs the stuff that is on a factory one and thanks about the van i thought i would build something that hasnt been done before and alot of people love it so thats a good thing well just let me know what i can do to help
supravan
