Old 09-06-2008, 08:04 PM   #1
Mahonri
Mahonri is on a distinguished road
Default Possible suspect in Turbo lag and vacuum problems
Alright, I have gone through most of the vacuum lines and haven't seen any that need replacing. Although I did stumble upon this little issue.
Im fairly new to turbos in general, could this be the problem that is causing the lack of boost? My other concern is if the turbine and wheel are in ok condition, seeing as how they can suck up some nasty stuff with the hole like that.
Thanks,
-Ryan
Mahonri is offline   Reply With Quote
Old 09-06-2008, 09:37 PM   #2
CyFi6
Ya, that needs to be fixed. Unmetered air can cause all sorts of issues.
Old 09-06-2008, 10:07 PM   #3
Mahonri
Alright called the Dealership, to order it in they want $124.64. That to me seems way out of the ball park. I could just change out that system for an after market system, that probably is just a bit more then what they want for that stock hose. Anyone know of a good kit? Apex-i, HSK, ect..
Old 09-07-2008, 01:35 AM   #4
Chambers
Chambers's Avatar
I know for about $160 you can get a silicone tube to replace the accordion hose, it has all the barbs for stock routing of hoses.
Intake Tube Link
Hope this helps, good luck.
"Stuck in the 80's"
Old 09-07-2008, 06:23 AM   #5
Mahonri
Hey thanks for the link. Doesn't look too bad, have you used one before? I was wondering if that small leak is what is wreaking havoc on my boost? It doesn't seem to me like that small tear would really slow things down like that... But I am hoping that I am wrong and things will be up and running great after that replacement.
Old 09-07-2008, 07:57 AM   #6
CyFi6
either way, thats something that needs to be fixed, and if it doesnt solve your problem you can be sure that's not your issue and move on to other things.
Old 09-07-2008, 03:24 PM   #7
Chambers
Chambers's Avatar
Well I haven't used one because I have a NA engine, but like CyFi6 said, it needs to be fixed!!
Good luck.
"Stuck in the 80's"
Old 09-14-2008, 08:38 PM   #8
fienloco
fienloco's Avatar
fienloco is on a distinguished road
I guarantee thats the problem. I just replaced the same accordian hose to a stock one from the dealer ($124.00). Had duct taped mine to try and seal it as it was old and cracked the same no boost or so little it was unoticeable. Replaced it and the three hoses off ($80.00)of it and problem resolved. Good luck with that its an easy, yet semi pricey fix.
fienloco is offline   Reply With Quote
Old 05-16-2010, 10:39 PM   #9
As I said before.... someone found a source for a replacement that was very reasonable... around $45, IIRC. Search for "accordion hose" and you're sure to find it.
