Old 09-03-2008, 11:10 PM   #1
arthd
arthd's Avatar
arthd is on a distinguished road
Question Oil leak
I just purchased a 1989 turbo supra. When I bought it, it had a oil leak in the front end somewhere. I thought it was the front main or crankshaft seal, upon closer inspection it does not appear to be leaking from under the pully like it normally does. I think, looking closer under the hood, it is probaly a oil cooler line. It appears to be coing form the drivers side, I was wondering if anyone knows if there is a problem area that I might start with, something that is notoriously known to leak. Just wanting to speed up the process. Thanks
Also, this is an excellent forum, so much useful info!!!! Thanks to all involved!
arthd is offline   Reply With Quote
Old 09-04-2008, 01:19 AM   #2
mastergrader007
mastergrader007 is on a distinguished road
i dunno if this helps but i had an oil leak and it was on the bottom of the oil cooler. the hole was in the steel line so i bought some longer hose and slid it up past where the hole was. its on the drivers side right next to the rad on my 88 turbo
mastergrader007 is offline   Reply With Quote
Old 09-04-2008, 06:07 AM   #3
Grandavi
Grandavi's Avatar
When your unsure of a leak, park the car on either paper or cardboard. Leave it overnight. Then in the morning... mark where your tires are on the paper/cardboard (so you can judge distance correctly and that will tell you approx. where the leak is. Remember that oil can travel a bit before it drips, especially if the leak is only while running (the air can push it back all along the bottom of the car)
Oil Leak. supramacist MKIII Supra 0 05-01-2008 01:18 AM
Coolant Leak bossman MKIII Supra 2 04-12-2008 09:31 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
