Old 08-29-2008, 03:18 AM   #1
matt7mgte
matt7mgte is on a distinguished road
Default Rebuilding 7mgte-Any suggestions
I am currently pulling the motor out and ordering a new long block for my 7mgte. I want to build it to about 500hp. I plan on upgrading the turbo to get 15lbs of boost and I don't know if I should buy forged pistons and whether or not to use a steel or copper head gasket. I am also adding a downpipe, water injection, and a stahl. Would porting and polishing the head and intake do much for hp to make it worth the extra money. It cost $500 for stage one and $1000 for stage two on the head work but with the other upgrades I dont know what to expect for hp out of it. I was also thinking of buying a cam, there is a stage 2 cam for about $500 and stage 3 for $1000 with new springs and such to handle the rpm. Is it worth it? I don't want to put much more into it because it is already costing about 6k!
matt7mgte is offline   Reply With Quote
Old 09-03-2008, 02:25 AM   #2
Stupra
Stupra's Avatar
Stupra is on a distinguished road
Hey. definitely go with a cometic steel gasket and arp head studs or bolts. Note: bolts are much easier because with studs you have to put the head on with cams out because the studs are too close to the cams to start the nuts. Although studs are proven to be better. As far as porting and polishing can't help you there. Cometic is a PROVEN company though. check them out
When life passes you by, DOWNSHIFT!
3 inch exhaust, cometic head gasket, arp studs, lexus afm, 550's, custom front fed intake manifold, FM intercooler, daily driven at 12 lbs.]
Stupra is offline   Reply With Quote
Old 09-03-2008, 03:32 AM   #3
mkiiisupra
http://www.arizonaperformance.com/parts.html\
AZP Oil pump supply kit
And a cheaper alternative....
Welcome to Driftmotion!
1990 Toyota Supra Turbo A/T
Old 09-04-2008, 09:52 PM   #4
SideWinderGX
SideWinderGX is on a distinguished road
The last thing you want to do is cheap out on quality because your too cheap. Do it right the first time.
You don't need to upgrade internals if your only going for 500 ish hp. Make sure to get a good tune out of it, otherwise you'll have problems. Don't bother with cams...a head upgrade definitely wouldnt hurt you though (valves and springs, etc, whatevers in the Ferrea package). Porting is ALWAYS a good thing, but don't port the lower intake manifold too much, it'll mess with the fuel vapor.
Eesh. Don't stick to any one company, number one. MHG is definitely the way to do (metal head gasket). Do head studs (again, don't cheap on quality because your lazy), they will hold much better.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 09-05-2008, 12:57 AM   #5
Stupra
Stupra's Avatar
Eesh. Don't stick to any one company, number one. MHG is definitely the way to do (metal head gasket). Do head studs (again, don't cheap on quality because your lazy), they will hold much better.[/quote]
Agreed. Studs are much better. And no you don't have to stick to any one company a MHG is just the way to go. I've learned the hard way on a rushing a project and cheaping out. The second time around I took my time and money and did it right. I would highly suggest doing that the first time as it will save you MORE money in the long run
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
7mgte - Any suggestions? RSCelica Non-Generation Specific Questions 1 07-30-2007 09:32 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
