Old 08-12-2008, 03:41 AM   #1
lunar0utlaw
lunar0utlaw is on a distinguished road
Default -------non turbo upgrades+++++
i got a non turbo the guy that had it be for me never changed the oil so i did a mkIII swap and i would like to repair the old engine and put a turbo in the car and would love to get 600 horse out of the beautiful old girl. i love supras to death and will make her as beautiful as they can be. and im not a ricer so she is in good hands. but in short i wish to know ways to put a turbo in her and daw as much hourses as posable with keeping with a MKIII engine. i just think it is a beautiful engine and car. so i wish to get any help i can get. thank you vary vary much.
lunar0utlaw is offline   Reply With Quote
Old 08-12-2008, 01:50 PM   #2
Chambers
Chambers's Avatar
I would find your self a complete 7M-GTE engine with a R154 tranny. There are a few differences that the NA block and tranny might not allow 600hp.
The GTE block has oil squirter's that help lubricate the rotating assembly, the NA does not. When you plan to push that much horses you will be wanting that extra lube.
The GTE also has the oil drain from the turbo in the correct spot, on the NA if you just drill a hole in the pan and weld a fitting onto that on a hard left turn you could possibly choke up your turbo and be hurting. It may be possible to drill a hole where the oil drain should go and tap it for a AN fitting, but if that worked you would sill be out of the oil squirter's.
Do not assume I'm telling you don't try it will never work, I don't know if the NA will hold that kind of power, it might. But if it doesn't, you will be deep in the money hole.
As for the NA tranny, its the W58, the common number for max horse power in them is about 400, any more and you will be looking at blowing a gear.
Either way you chose to do this, good luck.
"Stuck in the 80's"
Old 08-12-2008, 09:36 PM   #3
lunar0utlaw
thank you vary much. that is some really good food for thought.
plz mor feed back on were a good place for a good tranny may be . and about the ecu change if i was to go with a mkiii turbo engine as well as the wireing of the car.
Old 08-20-2008, 05:20 PM   #4
cme_drft
cme_drft's Avatar
cme_drft is on a distinguished road
You really are better off starting off with the Turbo mk3.
87 N/A R154 94 BMW 325i 4 SaLe
84 L-type RIP 08 Jetta Wolfsburg
cme_drft is offline   Reply With Quote
intercooler\ turbo upgrades cobrakiller MKIII Supra 2 11-21-2005 06:41 AM
