Old 08-04-2008, 04:34 AM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Unhappy BOV stall
ok so i adjusted my BOV so that I don't stall when i depress the clutch but now the engine makes a pretty bad clicking noise when i step on the gas. any ideas what's going on?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 08-04-2008, 12:10 PM   #2
Chambers
Chambers's Avatar
Does the sound have a plastic clicking sound to it? If so, it may be possible that something is hitting the fan.
Good luck.
"Stuck in the 80's"
Old 08-17-2008, 02:08 AM   #3
robertsws
robertsws's Avatar
Exclamation
no it was a metal clicking coming from the engine. turns out that my head gasket lasted even less time than i expected it would with the upgraded turbo.
stock head gasket and a 60-1 turbo don't mix, which i already knew. i was just trying to hold out for a few months. stupid me. anyway the clicking was the result of the coolant washing away the oil, in other words metal to metal, no lubrication.
so i'm off to install a MHG with ARP studs.
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
Old 08-17-2008, 03:54 PM   #4
Chambers
Chambers's Avatar
Ohh geeze, make sure you check your bearings, the lack of oil may have damaged them.
Good luck.
"Stuck in the 80's"
Damn idle! SCRAMJET MKIII Supra 10 02-19-2009 01:45 PM
Choking and stall on startup Durandal MKIV Supra 4 09-24-2008 10:32 PM
High stall torque converter southernsupra1 MKIII Supra 1 07-09-2006 11:24 PM
