Old 07-30-2008, 05:03 AM   #4
btwilson86
Super Moderator
btwilson86's Avatar
Power/ground to ECU could be the problem... The injectors are controlled by it. One test you can do (if it's dark out) is to get a 3V LED from Radio Shack or somewhere similar. Pull each injector plug off (one at a time to avoid confusion), and stick the contacts for the LED into the harness plug. Have someone try to start the engine. If the LED flickers (it'll flicker very rapidly if it does), then you're getting power to the injectors and it's not likely an electrical issue. Be sure to do this at night, as the LED will be on/off so quick it doesn't get much of a chance to illuminate.
Trust me, this works. I did the same thing on my 7MGE when I swapped it into my 87 N/A. It wouldn't start due to the distributor being 180 out, but I was checking all the possible reasons for it not to start.
Let us know if this helps, and also be sure to check at the ECU for Power and Ground.
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
Fuel injectors Biku Off Topic Forum 7 07-23-2005 04:36 AM
