Old 07-24-2008, 02:50 AM   #1
restomod
restomod is on a distinguished road
Default Front passenger brake locking
Has anyone run into this problem and how did you fix it? The front passenger side brake locks. It seems that the ABS Actuator does not allow the FR line to release the pressure once you hit the brakes. If I loosen the line from the ABS Actuator, then the brake releases. Any help would be appreciated.
Restomod
89 Turbo Supra
restomod is offline   Reply With Quote
need help replacing 89 supra front and rear brake pads 89supra323 MKIII Supra 16 05-25-2007 12:43 AM
