Old 07-16-2008, 05:02 PM   #1
suprabahamut
Default codes 42 and 52
I just checked today and I got codes 42 and 52. One says vehicle speed, and the other knock sensor. What does the knock sensor look like If it is a wire with a big round rubber shield hook to it, I plugged it back in it was lose near the oil filter. If this is the right one do I need to pull the battery cables off and check it again? And for the vehicle speed sensor will a bad speedometer cable cause it to read like this? I know the speed sensors are for the ABS I just wanted to know if it has any connection. If any one has any clue please respond I need all the help I can get.
Old 07-16-2008, 05:46 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
That’s the oil pressure sender unit, the knock sensors are HERE on the other side of the block.
Old 07-16-2008, 10:36 PM   #3
suprabahamut
Yeah the oil pressure started to work but still went back to the 0. I think I have to hook up something else as well for the oil pressure. I got a replacement motor at tiger japan 8 months ago so I know the oil pressure is stable but still would like the oil pressure gauge to work. As for the knock sensors thank you I am going to check the connections tomorrow. What do you think about the speed sensor?
Old 07-24-2008, 07:56 PM   #4
suprabahamut
The connector is broken on the knock sensor so I have to find out if there is a way to fix it. For the vehicle speed sensor, where is it at? and how can I clear this code?
Old 07-28-2008, 12:20 PM   #5
mkiiisupra
www.SUPRAS.com - Member's Section
If the sensor is broken they are quiet expensive but if not its more than likly your wire'n and that link should help u rewire it.
1990 Toyota Supra Turbo A/T
Error Codes 42 and 43 Getphazed MKIII Supra 6 09-14-2008 10:32 PM
Codes 25,26,51! justin1642 MKIII Supra 11 08-30-2007 08:08 PM
codes 22 24 31 kidthunder650 MKIII Supra 16 04-12-2007 11:54 PM
Got Codes? h8z2luze MKIII Supra 14 08-29-2006 01:48 AM
fault codes on a newly re-headed supra lethalwithasupra Non-Generation Specific Questions 5 09-28-2005 08:22 AM
