Old 06-28-2008, 04:49 PM   #1
Chambers
Chambers's Avatar
Default Having Trouble Removing the Steering Wheel
Hi all, When removing the steering wheel after you remove the 19mm bolt behind the face, how do you remove the steering wheel? Its splined but it wont budge, does anyone have any ideas to help remove it? I have the steering wheel that has the cruise control buttons on the 9 and 3 o'clock positions.
Also, I found the reason my cruise control doesn't work, its because there is no plug for it behind the face, the buttons have the harness that should connect to a plug under the wheel, but there is only a plug for the horn, has anyone else ran into this?
Thanks.
"Stuck in the 80's"
Aftermarket steering wheel RTZ MKIII Supra 10 02-07-2008 08:44 AM
Steering wheel off-centre colin172 MKIII Supra 3 10-06-2006 01:41 AM
What do i need for my steering wheel. paula Non-Generation Specific Questions 1 07-17-2006 01:03 PM
Steering wheel. lifesnotfair MKIII Supra 11 12-30-2005 12:26 AM
