Old 06-25-2008, 06:50 AM   #1
grabber
grabber is on a distinguished road
Default 4runner 7MGE swap idle problem
I just swapped a 7MGE into my 4runner. pretty sure i've got everything hooked up right and it runs great... only problem is at low rpm it idles up to around 2000 rpm and then drops off to 500 rpm and back up. it does this consistently. 3 seconds at 2000 rpm and 1 at 500 rpm. I'm lost on this... any ideas? the CEL is not coming on...
grabber is offline   Reply With Quote
Old 06-25-2008, 02:15 PM   #2
Chambers
Chambers's Avatar
Make sure there is no vac leaks. Check all of the vac lines running around the throttle body and intake manifold, also your intake behind the MAF sensor.
"Stuck in the 80's"
Old 06-25-2008, 02:34 PM   #3
supramacist
supramacist's Avatar
The tps dashpot may need to be replaced.
Ofcourse you would probably be throwing a code 51.
Old 06-26-2008, 11:45 PM   #4
7M-ERIK
7M-ERIK is on a distinguished road
It might also be the idle speed control valve. Test the plug or listen to see if it makes a noise when you shut the car off.
'89 Turbo 5spd Targa - 3" exhaust, RT Downpipe, Suprasport elbow, big fmic & pipes, Tein HR coilovers, NGK plugs/wires, Lexus AFM, Apexi SAFC, ARP head studs, TurboXS mbc, removed all A/C garbage, elec. fan, rebuilt CT26, mild port matched turbo hot side
7M-ERIK is offline   Reply With Quote
7mge swap, electrical problem 89n/aA/T-2turbo5spd MKIII Supra 5 08-15-2007 06:51 AM
7MGE to 1JZGTE engine swap help please! seek102287 Non-Generation Specific Questions 2 07-02-2007 12:57 AM
Idle problem again. redmaro MKIII Supra 17 02-10-2007 07:42 AM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
