Old 06-23-2008, 05:24 PM   #1
suprabahamut
Default Instument light on
What is this warning lamp for, I have tried to describe it but could not do it. I finally got a picture of it. It only comes on when I hit the brakes.
Old 06-23-2008, 06:03 PM   #2
supramacist
supramacist's Avatar
Check to make sure your brake bulbs are functional and not installed incorrectly or blown.
Old 06-23-2008, 07:45 PM   #3
suprabahamut
They all work when the brakes are applied. I have heard it could be the wrong bulb is this true? But the light is for the brake lights right.
Old 06-23-2008, 08:25 PM   #4
supramacist
Maybe it's your reverse lights.
I have not had this problem.
Old 06-23-2008, 09:46 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
I remember seeing that symbol in a 007 James Bond film, Bond was driving an Aston Martin, its something to do with squirting oil out the rear, or a warning to tell you that the rear bumper is about to fall off. Although I think supramastic is right, it’s a rear brake bulb failure warning light. If the bulbs are ok then is most likely a bad/corroded connection in the bulb fail unit module, which is located on the right hand side (looking from the rear) near the rear light cluster. On the UK models it’s a blue box that often becomes wet due to a hatch leak.
Old 06-23-2008, 10:48 PM   #6
7M-ERIK
7M-ERIK is on a distinguished road
I have this problem as well, except it comes on when I put the car in gear and stays on until I shut the car off. It might be for the reverse lights or something idk I'm pretty sure none of my lights are out. Could it be on for a dead LED in the rear wing?
'89 Turbo 5spd Targa - 3" exhaust, RT Downpipe, Suprasport elbow, big fmic & pipes, Tein HR coilovers, NGK plugs/wires, Lexus AFM, Apexi SAFC, ARP head studs, TurboXS mbc, removed all A/C garbage, elec. fan, rebuilt CT26, mild port matched turbo hot side
7M-ERIK is offline   Reply With Quote
Old 06-24-2008, 12:23 AM   #7
Chambers
Chambers's Avatar
It is for all rear lights, and the rear side markers, I could see a dead LED causing it.
When I picked up my Supra some of the bulbs were stock Toyota, lol. The first one I went to replace shattered from the pressure of my fingers and cut me pretty bad, I had to use a pair of pliers after that to loosen the bulb, did the same for another three bulbs. The third brake light was also out, literally, all I had there was two wires, lol, I still haven't gotten around to buying a socket for it. The weird thing is that after a few months of driving the warning light stayed off, and it hasn't came back on since.
"Stuck in the 80's"
Old 06-24-2008, 01:21 PM   #8
suprabahamut
I think it is a bad connection, when I am at a stand still the lights work and my brother told me yesterday that one of my tail lamps was out. When I got home I told him to hit the brakes and see for my self and they still work, so it probably is a bad connection.
Old 06-24-2008, 10:34 PM   #9
Chambers
Chambers's Avatar
Yea, that reminded me, I had a similar problem with a light going out and then coming back on later. I took some WD-40 and sprayed the entire light assembly's and the light failure box, that solved my problem because of the water running down behind the tail light from the hatch was causing a bad connection.
"Stuck in the 80's"
Old 06-25-2008, 01:57 AM   #10
suprabahamut
I think this is exactly what is happing chambers. I have seen water running out of the hatch near the 3rd brake light. I will put some WD-40 on near the connection. How do you stop the leak?
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
light on dash that tells you a light is out D_Train MKIII Supra 7 08-04-2007 05:10 PM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
light issue kewlcoconut MKIII Supra 5 11-24-2005 04:28 AM
