Old 06-23-2008, 05:21 AM   #11
3.0trd
3.0trd is on a distinguished road
I had a bad tps, but mine would idle high, I figure it could do the same the other way, it was about 100, but I have an N/A... might want to test it
Cometic MHG, ARP studs, H&R lowering springs
3.0trd is offline   Reply With Quote
Old 07-04-2008, 03:07 AM   #12
RspecMKiii
RspecMKiii's Avatar
RspecMKiii is on a distinguished road
So it turns out that IT was my tps that was bad on the supra....she runs sooo much better now. Now i gotta find out which part number is which on the eibachs to see if they are reversed. Thanks all for the info to help me out.
RspecMKiii is offline   Reply With Quote
Old 07-04-2008, 03:29 AM   #13
Chambers
Chambers's Avatar
Good to hear you got it going.
"Stuck in the 80's"
Old 11-05-2009, 01:56 AM   #14
dupra87
dupra87 is on a distinguished road
Default idle
hello there i have a 87 that does the same thing. i put a vent on it and then it started doing it real bad so i adjusted it all the way down and it's better but still does it sometimes . sooo annoying.
dupra87 is offline   Reply With Quote
