Old 06-08-2008, 01:34 PM   #1
TomFraser
TomFraser is on a distinguished road
Default Hatch Open Warning Light constantly on...
Does anyone know where the sensor is for the car to know the hatch is down? All I can find is the light sensor.
Thanks!
TomFraser is offline   Reply With Quote
Old 06-08-2008, 10:21 PM   #2
TomFraser
When I say sensor it could be a button or just 2 metal contacts... can't find it by looking at the:
Electronics Parts Catalog
parts catalogue either
Old 06-10-2008, 07:18 AM   #3
kwayne
kwayne is on a distinguished road
Default Hatch Open Warning Light?
Which warning light are you seeing? Can you post a pic? The reason I ask, is I was getting an amber warning light whcih I thought it was open hatch warning light. But, it turned out to be the illumination warning light. The problem was corroded grounds on the tail lights.
Try removing the tail light assemblies. They just snap out. Removing the ground wires, cleaning the contacts and reassembling.
kwayne is offline   Reply With Quote
Old 06-10-2008, 10:38 AM   #4
TomFraser
thanks... i will do that and post a pic when I get a chance, it is the light to the left of the door open warning light on the dash panel, and is amber
Thanks
Old 06-10-2008, 01:35 PM   #5
TomFraser
THANK YOU... It was the illumination warning... I will be hunting down the problem tonight
Old 06-10-2008, 03:17 PM   #6
TomFraser
So... the idiot owner before me decided it would be a good idea to use the supra to tow a uhaul trailer, I took off the back left panel inside the trunk and saw the trailer attachment wires (badly connected) and didn't want to bother unconnecting, and also saw a yellow box that said "Lamp Failure" I unplugged this yellow box and will have no more issues with the warning light, however I have to check the lights every now and then because I no longer have that feature.
EDIT: Just making sure I was clear... to disconnect the system, cut the yellow wire going into the yellow "Lamp Failure" box, DO NOT UNHOOK THE BOX AS THIS WILL MAKE YOUR BRAKE LIGHTS NOT WORK!!!!
Old 06-13-2008, 02:07 AM   #7
TomFraser
Wiring your MKIII Supra around the Lamp Failure Box - Supracentral
kinda an old thread but maybe someone will find it with a search someday and need this
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Warning light question scruffboy Non-Generation Specific Questions 4 06-11-2007 11:16 PM
Warning light question thetrueaint MKIII Supra 4 08-29-2006 06:07 AM
Air Bag Fault Codes: 14 Squib Malf open & 22. Warning light, Please Help!! Jap Imports MKIV Supra 3 06-07-2006 03:59 AM
battery warning light / tail lamp failure warning light MattJ MKIII Supra 5 02-06-2006 07:22 PM
