Old 06-08-2008, 03:34 PM   #11
Bill UK
AEM EMS
Bill UK's Avatar
Unplugged or plugged in its not doing anything as it is, the two wires that are connected are heater wires for the ox sensor, the broken wire is the sensor/signal wire, you really need to connect that back up. Not sure if soldering is advisable as the wire may be used to measure resistance back from the sensor.
Old 06-08-2008, 06:22 PM   #12
JPJ
JPJ is on a distinguished road
Thanks Bill, I understand your point about not using soldering as a repair method here, but with such little exposed wire to work with, I can't think of any other option... it's broke almost at the very back of the plug.
Thanks again
JPJ is offline   Reply With Quote
Old 11-30-2008, 11:21 PM   #13
supra4life1386
supra4life1386 is on a distinguished road
definatley your 02 sensor i just had that happen to myne and i mated the wires together definately is an 02 though
supra4life1386 is offline   Reply With Quote
where and wha color is the speed sensor and rpm signal wire 88Tsupra MKIII Supra 6 03-16-2011 07:48 PM
Question on wire for rewiring KS redmaro MKIII Supra 8 09-30-2007 04:11 AM
Antenna wire? supraman121 MKIII Supra 3 03-26-2007 03:59 AM
need help: wire coming off A/C compressor - to? theWeezL MKIII Supra 5 05-17-2006 11:26 PM
