Old 05-22-2008, 02:24 AM   #1
Chambers
Chambers's Avatar
Question 7M-GTE - "Light" Re-Build Question
Hi all, I was thinking of buying a 7M-GTE. If I go ahead and buy it I won't be looking for a lot of horse power, just a step up from a NA.
My question is, what should I look into for a "light" re-build, besides the obvious head gasket and machine work, assuming everything checks out such as compression, valve shim clearances, and theres no sign of incorrect wear on any components in the bottom end. Thanks.
"Stuck in the 80's"
Old 05-22-2008, 02:27 AM   #2
supramacist
supramacist's Avatar
Since you aren't shooting for major hp gains but seemingly reliability.
I may mention a 2jzge swap.
Old 05-22-2008, 02:53 AM   #3
Chambers
Chambers's Avatar
I had seriously considered that and searched into it a little but I'm having the hardest time finding any place online that sells a 2JZ-GE with a computer, harness, and transmission.
If I had to I could re-wire a harness or make a new one but I would rather stay way from that. The other problem is since my car is a pre-89 the front sub frame cross members and engine mounts are slightly diffrent, I know BIC makes engine mounts for a 2JZ swap in a pre-89 but I don't know about the cross member.
It seems to me that staying NA with a 2JZ would be a better route for simplicity reasons, less stuff making power = less stuff to break.
By the way, I'm liking the new avatar supramacist!
"Stuck in the 80's"
Old 05-22-2008, 03:41 AM   #4
supramacist
The way I understand it is the w58 will work with the 2jzge.
If you have an r series trannt, you only need a bellhousing.
I hear the harness's are very close you're stock should need minimal modification.
You would also need jza80 mounting brackets an an 89+ crossmember.
Old 05-22-2008, 01:33 PM   #5
Chambers
Chambers's Avatar
I found some mounting brackets from BIC performance that would allow the 2JZ swap with out changing the cross member.
Thats cool that the W58 will work, I didn't think it would work. Thanks.
"Stuck in the 80's"
Old 05-22-2008, 04:09 PM   #6
supramacist
You don't think the engine could un-torque itself without a cross member?
I'm asking. I don't know. Some say it's possible without the cross member and have mentioned specifically the bic brackets.
I have read this enough that there must be some truth to it.
It's to widely spread. It's like someone saying Jimmy Page is a practicing occultist.
Old 05-22-2008, 11:57 PM   #7
Chambers
Chambers's Avatar
Hmm... I see what you are saying. hehehe
I guess I will stay 7M then, I prefer the grunt of a 7M to the wirr of a JZ anyway, lol.
Swapping a engine in is one thing, but taking the chance that it would backfire on me from something like that is not worth it without swapping the cross member, the only problem is, I wouldn't swap the cross members without replacing every bushing I came across, and those bushings are up in price, so a cross member swap isn't in my direct future.
Back to the original topic, I'm thinking of replacing; as many gaskets as I can get to, head gasket, and new vac lines. Can you think of anything else?
"Stuck in the 80's"
Old 05-23-2008, 12:11 AM   #8
supramacist
Vac hoses and Coolant hoses. And torque those suckers tight.
Now's a good time to do an ac delete.
I'd replace the starter just so I knew I wouldn't be trying to yank it to inspect it.
T-stat housing gasket.
EDIT: Injector grommets.
Old 05-23-2008, 02:29 AM   #9
Chambers
Chambers's Avatar
You and your ac/heater core delete, lol. Yea the stuff is heavy but they suit me for my uses of the car.
I forgot about the injector grommets!! Thanks!
"Stuck in the 80's"
Engine build question... 2JZEFINI-17 MKIII Supra 2 01-04-2007 10:29 PM
Engine build... h8z2luze MKIII Supra 5 12-08-2006 03:55 AM
