Old 05-12-2008, 11:44 PM   #1
mc_p0pe
mc_p0pe is on a distinguished road
Default Running Rich! Help needed
Hey guys,
I have a 1989 toyota supra turbo and when i boost my sensor says it is running rich. I checked and i do have signs of a rich mixture and am not sure what i should do. I think it is do to a boost leak, but i'm not sure any ideas? Also, when i start it for the first time everyday it takes awhile to turn over and starts kinda rough. I was thinking that it may be the cold start injector, but once again i am not sure. Any help on eith subjects would be much appreciated.
mc_p0pe is offline   Reply With Quote
Old 05-13-2008, 03:27 AM   #2
mc_p0pe
No one has any ideas huh? Throw me a frickin bone here...
Old 05-13-2008, 03:44 AM   #3
1989 8secmkiii owner
1989 8secmkiii owner is on a distinguished road
Default vaccum leak
it sound to me like a vaccum leak or its a faulty sensor.
1989 8secmkiii owner is offline   Reply With Quote
Old 05-13-2008, 04:48 AM   #4
supramacist
supramacist's Avatar
MK3 TSRM On-Line
I'm an N/A. So this tsrm is about the best I can do for you with what you're asking.
Have you metered the battery?
Pull Codes.
Cygnus X1 Home Page
Old 05-13-2008, 10:15 AM   #5
Cool
i bet you are getting code 51 and 24
i would check the vsv switches under the intake
Old 05-13-2008, 08:17 PM   #6
mc_p0pe
I checked and there are no error codes, i just hooked up the knock sensors and all is well. My car has an extremely big hks super dragger exhaust and a megaflow intake on the turbo and it is boosting to about 11with stock turbo and injectors... i think this is close to the fuel cutoff point and dont know why it would run rich. my vaccuum pressure is also about 19-20. if this helps any, please respond
p.s. did you mean a faulty o2 sensor or mixture sensor because there is extra soot in the exhaust proving it is rich?
Old 05-13-2008, 10:29 PM   #7
Default running rich
check the resistance if that o2sensor it should be around 0.3ohms + or -.2 and additionally check tps.
Old 05-13-2008, 10:32 PM   #8
Default engine
ddmcse hey where did u get the engine from and is it stock.
Old 05-14-2008, 06:56 AM   #9
supramacist
It may sound redundant..., but check your timing.
I think these cars naturally run a little rich..., atleast for there age.
Mine does as well. My answer you ask?
A Fuel Pressure Regulator. MSD makes one.
Horsepowerfreaks.com sells them as well.
Don't cheap out and get one from the local parts barn unless you just want to test it before you invest real $$$$ into 1.
You can spend anywhere from 60$ /150$
I personally think something in the 100$ range would suit my needs and maybe yours.
These are just opinions and there's a reason they're free.
Old 05-14-2008, 10:20 AM   #10
Cool
if you are going to modify a turbo'd supra
put an air/fuel meter on it .
air/fuel mix is extremely important for a turbo's supra
there is a reason why these cars run a little rich ,
it's to keep idiots from wrecking the engine once they start to modify things like they know what they are doing
the oxygen sensor could cause it to be a little rich but when i swapped mine out it didn't help.
it was my vsv valves . i tried all kinds of things checked everything , you wonder how a turbo forcing air into the engine could make it rich in the first place .
i replaced the start injector too .
a simple continuity check on the vsv showed it was out of spec . replacing both of them gave me instant gratification with a nice and balanced air/fuel meter ..
you have to have an air/fuel meter if you are going to start messing with a turbo supra .
you need a baseline
Running Sooooooo Rich! Help! godgaveussid MKIII Supra 4 08-29-2007 08:46 PM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
Running rich! grygst76 MKIII Supra 6 09-29-2006 01:56 AM
fuel running very rich famous Non-Generation Specific Questions 8 08-17-2006 01:49 PM
fixed the running rich problem djalkyd MKIII Supra 6 05-04-2006 04:31 AM
