Old 07-06-2005, 07:00 PM   #15
ddmcse
ddmcse's Avatar
i do not know for sure
but if you say the car is running great with no signs of a knock
i would guess that the sensor is bad or the connection is not good or a cracked wire causing the error code and drive it .
when i put my engine back together one time i didn't get a good connection on the one next to the starter and got the same code . i was freaked for sure but i resolved it quick because i knew that one was a mother to re connect.
if you get it off it's going to be difficult to get it back on .......might be easier to pull the starter
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
turbo? Knock sensor? running lean? west_side_supra MKIII Supra 19 02-01-2009 07:28 AM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
Bad Knock sensor TWRViper MKIII Supra 5 08-31-2005 09:24 PM
